Weird problem with air con
coops10
Newbie
Sep 1, 2009
734
Middlesex
www.coops-photo.co.uk
Ok so I tried to turn the air con on last night which I very rarely use, if ever. I press the button, the snowflake appears but as soon as I let go of the button it disappears ! So basically it wont stay on.
Around 20mins later I notice the engine management light has appeared on the dash. Car seems to be running fine, no misfire etc.
Would the air con problem be likely to be the cause of the ecu light to come on?
Any idea what would cause this ?
Anyone near the HA4 postcode that has a fault code reader that could spare 15mins to help me out ?
Thanks.
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
if you hold the aircone button in you supposidly over ride it , but once let go it disappears
but as said below a certain temp it wont work
the mrs's megan works in any temp and hasnt blown up yet so cant see why its a safety thing
mines seems to work above 1 degrees up
Dajmin
Maybe they just don't want you getting a cold, sitting in freezing temperatures with the A/C on :)
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
You do understand that the "snowflake" symbol indicates that the air cooling compressor is in operation, don't you? I can't contrive of any way to make that warm you up quicker . . .
welsh frtdi
smokey
Oct 3, 2009
66
carms
sound s lto like you possibly have a faulty compressor switch(possibly if it dont work when temp is up over2'c)the switch recocnises gas pressure when you engage the button ie it sends a current to the compressor cluth to engage the pulley if you look at the front of your air con compressor when air con is off the front part of compressor should not be turning as the clutch is disengaged. try listening for a click from compressor when air con is engaged. the switch sometimes causes a fault linked to the ecu when low gas content is detected. if theres no click when you engage the air con test the switch or give it a live(12v) this is only a possibility.dont try that unless you well sure of what your doing.
coops10
Newbie
Sep 1, 2009
734
Middlesex
At the time I was too cold to think of this lol :wtf:
Ill wait until it gets warmer and give it another try, was 1.0deg all day today :(
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
The air cooling compressor will not engage if the outside air temperature is 4°C or less. The best explanation I've come across is that this prevents ice formation on the cooling matrix which would block the cabin air intake.
Cabin air comes in via the pollen filter and then hits the fan. After this is the air cooling matrix, across the full duct so all the incoming air is cooled. Then the duct splits, one half to the heater matrix, one half straight through. The desired cabin air temperature is achieved by mixing the two.
In the summer, air cooling will cause moisture to condense out - cold air can't hold as much moisture as warm air. Heating it up again drys it out.
When the outside air is very cold it can't hold much moisture anyway, and there would be very little drying effect gained from trying to cool it further.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Here's a diagram of the ventilation system, to make it a bit clearer.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Well, as we have warmed up a bit today I tried running with the air cooling on at an outside temperature reading of 2°C, and the snowflake symbol stayed on indicating that the compressor was running. So despite what some of the books say, it's 2°C or less where the air cooling shuts off.
