Weird MAF Code
Nov 2, 2004
9,335
South Wales
Just check the car and got this code...
16487 - Mass Air Flow Sensor (G70) Signal too High
P0103 - 35-10 - - - Intermittent
The car runs great, no problems at all so whats this fault about? I'm sure i've seen it before as well.
Nov 2, 2004
9,335
South Wales
Nah its the original one, but my readings have always been low ish, never seen over 150 g/s. Will get out this week to log it.
Nov 2, 2004
9,335
South Wales
Well i'm seein some low ish g/s on the logs. Got 142.9 max this week. Gonna clean it this week and see what happens. I've only had this twice tho in the past year so i'm not that worried now. Just might have a maf problem starting, will keep check and post back.
Are you gettin this code regular?
fistic
Have you solved the issue ? I have same on my Octavia RS. Just after putting a branf new maf. No simptoms just ABS light and this MAF fault code.
fistic
Group A: 002 Group B:
Idle speed Engine load Inj. period Air mass in
TIME 700-820 rpm 15-25% 2.0 - 4.0 ms 2.0-4.5 g/s TIME
Marker STAMP /min % ms g/s STAMP
0.91 3360 12.8 0 8.56 0.01
2.22 2160 17.3 0 7.25 1.31
3.42 4120 60.9 8.84 51.19 2.62
4.64 4320 124.8 16.66 123.36 3.84
5.95 4840 163.2 19.04 185.5 5.04
7.24 5320 156.4 22.44 198.33 6.44
8.46 5600 91.7 9.18 117.78 7.64
9.67 4400 76.7 14.28 79.22 8.86
11.08 4680 183.5 21.08 165.58 10.15
12.38 4960 164.7 24.14 171.83 11.58
13.69 5160 154.1 23.12 186.22 12.87
14.89 5400 150.4 23.12 191.83 14.09
16.11 5560 148.9 23.12 198.06 15.29
17.4 5360 12.8 0 12.14 16.49
