weird clutch pedal
jattjoka01
109
London
just noticed a weird noise coming frm the clutch pedal and outside (more from the outside), when i press the pedal once ive had a good little drive.. it doesnt happen when the car is cold though... its a creeky noise.. ?? any ideas?
cuprachrissy
never had a prob like that before pal, when was the last time your clutch went?
a bit off topic but where abouts you from in london?
cuprachrissy
from south east mate, croydon. you go to any meets?
with the clutch have a search, might find some answers there pal.
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
quite a common one this it does it on mine aswell...
There has been a thread on this before have a search for it
Off the top of my head i think it may have been clutch release plate of somthing somone was having a go at trying to work it out but not sure how they got on...
Nov 10, 2004
1,000
Colchester, Essex
For the noise inside, I took off the plastic panel under the steering wheel/fusebox area, and just sprayed WD40 / Sillicon grease all around where the pedal goes, including the long spring, pedal bar etc.
Didn't make any difference for a day, then all of a sudden no noise! So worth a try.
Careful not to get it actually on the pedal itself though!
As for outside clutch noise, as mentioned above clutch release bearing, but that would generally make a noise when cold too.
