Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
is it true that using WD-40 on the spark-plugs cables,distributor,ECU, and other electris stuff, will improve the performance of the engine , i never used it to clean my engine anyway ,
any clue?
thanks
ive used it on my old astra when starting in the cold and wet. it helps eliminate water/damp. only used it when i couldnt start the car tho... not as a regular thing.
WD40 will drive out any moisture present. At best it's a short term fix, since the oil will evaporate over a few weeks.
The real answer is that you car is about due a new set of ignition cables - for which you'll probably find that your dealer is the cheapest place to get good leads. VAG use the name Quantum for their spares and they should cost £30 or so. 'Performance' leads are a waste of money (since they don't actually improve performance).
A new distributor cap and rotor arm will be £15 or so, and are worth doing if they haven't been replaced.
