Hi all, after discovering my saturated boot, my soaking wet passenger front and rear foot wells, and signs of mould I decided to investigate the problem. We found the rear washer tube had come off in 2 places! But could there be another problem? I've looked behind trim & door cards but cant see any evidence. Please read below...
First Leak Found
is behind the trim where the boot light is. Is it possible this could have been sabotage? because its been for a service recently and when I connected it back up it was really tight and clicked together. Anyways I used a bit of plumbing tape to make sure. This problem caused the entire boot matt, and side carpeting (where the 12v power socket was) to be soaked causing mould on the rear of the seat (passenger side) Also WD40'd around the inside of the arch to help clear water and to make a water proof seal to prevent rusting.
Second Leak Found
This is the second time I've had to repair this tube! So this time i added a little bit of glue around the base of the plug along with plumbing tape.
Now the only question I have now is why is there mould on the front passenger door at the bottom?
I read this fantastic guide on door seal leaking which appears to be common, but after removing the door card and examining the metal plate and rubber seal it appeared all ok and no signs of leaking even around the speaker. We poured water all over the outside of the window and door seals to see if any water was coming in but nothing. So we assume its all ok. We found mould near the passenger front seat mount along with mould under the front passenger door. I have to say we notice a lot of water in this area after its rained and we open the door which could explain the mould but surely there is something wrong here?
We then checked the back passenger door and appears ok, no signs of leakage.
Then lastly we checked the pollen filter. This was all secure and felt dry, apart from a few leaves it seemed fine.
So my question is the soaked carpets all from the disconnected water pipe in the boot of the car? somehow made its way behind the trim into the rear passenger foot well and then soaking the carpet towards the front? The rear is far more soaked than the front.
First Leak Found
Second Leak Found
