water in passanger footwell
johnty22
when its been raining i get a trickle of water theat runs in from the bottom of the passanger door when i pull away , if i opne the door before i drive off its fine as the water on the sill seems to disperse, any ideas?
stuart86
914
West London
www.britishmods.com
look at your pollen filter cover
its likely that it hasnt been fitted properly and the water is leaking in through there
the filter cover can be found under the bonnet top right corner as you look at it by the scuttle panel
NickT
429
LB, Beds
I may be wrong but I think the pollen filter leak comes in through the bulkhead and not via the bottom of the passenger door? :shrug:
