Washer Jets?
Arctic
466
Newcastle...ish
Had a go in my dads VW Jetta company car earlier, one thing i liked about it was the mist sylye washer jets (instead of squirts of water a mist is sprayed) can you get a conversion for the leon?
I done it on my 306 using xsara washer jets, wondered if any of the VW range would work?
panholio
333
Leeds
Hi Arctic!
I had a Mk4 Ibiza courtesy car and that had really good mist style washer jets. They look to be mounted in a similar place. Might get some from the stealer and give it a go.
willcooke
Brrrummmm
May 31, 2005
114
Beds
The Skoda Octty has them as well (at least our works estate does), part might be cheaper from a Skoda dealer?
AshCupra300
381
65
Newport, South Wales
Watch out - Schipps is shooting wide !!
I think you can do it (carefully) with a pin
Yep mine were doing this when I picked it up last weekend, adjusted them with a pin, but be very slight with the adjustments, took me about 20 mins of faffing to get them right, they were shooting over, then hitting the base of the windscreen, the adjustment is that tight.
