warped disc?
FRESHMODE
FRESHMODE
Oct 9, 2008
249
Staffordshire
Hi all
When braking from high speed or heavy I get a slight juddering/wobbly feeling from the front brakes area (pretty sure its more drivers side). The steering wheel doesnt shake and I've recently changed the rear discs, however my confidence in stopping quickly is slightly marred by this.
I did have a 'small' accident over xmas (few of you may know I slammed sideways into a curb!) As well as sorting the rear 'shafted' rear axle beam:whistle:, I've had new bearings/bearing housing/shock on the front drivers side which fixed all the 'driving in a straight line' issues i'm wondering if i've got a warped disc?
Can anybody shed any light at all?
cheers:D
robertj
weight is the enemy
It does sound like warp discs but given what you've said about hitting the kerb I'd be inclined to check over that front corner. If you had the hub dismantled it could be something as simple as a bolt not being tightened properly. (brake caliper maybe?)
