I get that pop up quite often. 1.2tsi se. I didn't even get any error codes when I plugged in my obd11 either... So at present it just gets reset when car gets restarted.Morning
I've recently had an intermittent warning sign pop up on the cruise control. See below:
Any thoughts what this could be?
Rob
I get this error at any speed..Just a guess, is the cruise speed set too high / too low maybe?
No... It cuts out....Does the cruise control work despite that warning?
Thanks for the info. Looks like myself and the OP are gonna have to live with it...Ah, sounds proper broke to me. I dug this thread up with what sounds like the same issue but no update to see if a solution was ever found / paid for...
https://forums.seatcupra.net/index.php?threads/cruise-control-error-on-dash.436903/
Thanks for the info. Next motorway run I will make sure my oil is at 90C before using the cruise control. See if it still happens.....My 15 reg Cupra 280 DSG started doing this about six months ago (I've had it 14 months). I've asked the dealers to look at it a couple of times but, in typical fashion, the error doesn't occur when it's with them and it seems that it doesn't leave a log of any error code - they claim not to be able to do anything without this information.
Through experimentation, I've worked out that the error only occurs when I use more than 2,500 rpm before the oil reaches 50 deg. C (not sure what happens in the engine at this point, possibly some change in the variable valve timing map?). I accept that I may be imagining it, but I've convinced myself that the low-end throttle response is not as sharp when the warning light is illuminated. This suggests that it may be the camshaft position sensor or something like that.
Intermittent electrical faults are a deil to trace and I'm loathe to just start changing random sensors so I've learnt to just drive around it by keeping below 2,500 rpm until the oil reaches 50 deg. C. I've never had the warning light appear once the oil has warmed up a bit but, as others have said, you have to restart the engine to clear the error.
Cool, can't wait to see if this fixes it..Mine has this, car going in for a new stalk next week, j
I haven't got my speed warning set. I'm thinking it's related to the cooling issues and EML they throw up.Could it be related to the speed warning setting? cruise set higher than what the warning speed is?
