Warning noises
Acksaw
Confused
Apr 25, 2009
289
Newcastle, Staffs
www.acksaw.com
Hey guys, reading through various threads I've noticed that people say they get a headlight warning light if they open the doors, if the temp is below 4C, when indicating and when the fuel is low..
I get none of these?
I ran VAG-COM and only got a problem with my MAP sensor which I wrote about in another thread..
Any easy/quick/cheap fix for this? Would love the indication and headlight noise as I miss those from other cars.
DEAN0
Old Git
Feb 1, 2006
5,356
347
Preston - UK
If I remember from another thread - there is a buzzer soldered to the circuit board of the clocks. that has probably failed try a search.
Ant FR
2,861
Kent
does anyojne know if we can have a nice beep like on other cars. The vw one is nce, my old mini was brilliant.
The Mk4 ibiza one scares the **** out of me, admittedly the fuel light comes on less, but it makes me jump everytime if blares out, not subtle at all.
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
In RS or maplins you can get a little speaker device with a set of dip switches on the side of it, it will make 100's of different sounds with a low voltage supply to it depending on the dip switch selections.
