Want to polish my charge pipe
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Could anybody tell me what i would need to get a mirror finish on my charge pipe once i have it off? Is it possible to do it by hand or with a drill with a attatchment on the end? Or is it a pro jobby?
pdcupra
Ibiza-less
Aug 11, 2006
743
King's Lynn
you need quite a few bits to do it properly, iv done a few now, and they are pretty easy - if you have the right tools. We use an angle grinder with different grades of polishing mops, abrasive first off to get rid of the deeps marks, then less abrassive to flatten it off, then a polishing one to get it mirror shiney, iv had very good results so far, its just time consuming.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
So what would i need to buy from that link to polish the charge pipe? and even the Manifold if im feeling keen!
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Hmmm that sounds more like it, how much are they charging you for you mani? dont suppose you know how much they charge for a charge pipe :D?
David.
caney
600
David.
they charge £20/hour so i would guess about 2/3 hrs? they laughed when i mentioned diy kits as they use a 5hp lathe to do their polishing on;) give them a ring and ask for paul:D
