W8 light wiring problem
coupelee
I just recently fitting the mk4 golf w8 light into my lc and all went well apart from now the airbag light it lit up all the time. Have i wired something up wrong here?
coupelee
At the dimmer switch connector which wire do i connect the new one to from the light.
GrayT
I'm Old
Jul 7, 2004
812
London
The dimmer wire is on the back of the headlight switch but that's interesting because the No.17 grey with blue that I tapped in to definitely dims my W8 light when I use the dimmer dial. I cannot vouch for what that red wire is in Pab's guide. Some people go directly into the headlamp wire because they say the W8 light is brighter from it, however, someone should be able to confirm what that red wire is!
coupelee
I've now changed the wire over to the number 17 on the headlight switch and and now the w8 light dims with the dimmer dial so that's now sorted :clap:
Just need to sort out the airbag light now has that's still on, looks like a trip to the local vagcom garage.
coupelee
no never did remove the glove box but i think i may of knocked some thing on the fuse box. Hopefully all will be sorted tomorrow.
