vw golf alloys
balders002
hi all
just need a bit of advice,i've been offered free of charge a set of alloys from a 55 plate 2.0tdi golf.will they fit my 56 plate altea 2.0 tdi stylance both are on 16'' rims
many thanks paul:confused:
Mike5
VW alloys
Hi
I hunted for a space saver a couple of years ago and found that the pitch centre diameter (PCD) of Golf wheels were a few mm smaller that the my Seat ones. This is the diameter of the 5 stud holes in relationship to a circle from the centre of the wheel that cuts through the centre of the fixing holes. The ofset of a wheel can also be different. You would this as both VAG products they would use the same hub units but this does not seem to be the case. Make sure of these issues first.
balders002
many thanks
for all your helpfull advice should be getting them this weekend hopefully,
will post when i get them fitted !!!!!
paul :think:
