Volumetric sensor button not workin?
muttly
200
Stamford Nr Peterborough
hey peeps ..just had a search but couldnt find the answer i wanted .. i wanted to leave me windows open and lock my LCR today
i know if ur press the volumetric sensor button below the drivers door u can disable them .. i removed the key from the ignition and pressed it for a second as per manual .. but no matter wat i did i could not get the light on the button to come on..which im guessin it does when u press the button and the sensors are disabled.. is this correct?
so if the light is not lit on the button it means they are still enabled and the button is not workin?
thanx for any info
matt
Cuprabob
89
Don't think the light comes on. I've used in the past, pulled out the key and pushed the button within a certain time and that's it disabled.
muttly
200
ok thanks for that .. it must of bin my imagination ...coz i coulda swore i member seeing a light on there when i used it after i 1st got the car..lol.. never mind as long as know its workin as it should..
thanx
matt
marshyc
299
Huddersfield
muttly said:
doh.. thats probly wat it was! :doh: haha
Could have been but I did have a look at my button after I posted and there is a point at the top left hand corner of the button which looks different to the rest. I think that may light up Yellow I think :shrug: it the button is activated.
Didn't try it as I was busy with some other stuff but I will give it a go and see.
muttly
200
yea i did notice that too .. which is also wat made me ask.. but i wasnt sure.. lol..:confused:
