1. Under the passenger dash, where the fan motor / heat resistor is located, is there meant to be a tray covering all of this up? There's two tapping screw tabs each side to hold something...
2. Also - there's a connector - a 2 pin connector roaming about under the dash - any ideas what this is?
3. When my car idles - it sounds fine with the clutch depressed in. When I release the clutch and let it idle in neutral - it does a crappy rattley noise... this is not all the time - but it is pretty often.
4. Since I've fitted my new multispokes - the rear wheels humm when I go round corners - and tend to humm too on new tarmac roads? Bearings?
5. At 60,000 miles - If I recall correctly - it says in the Haynes manual to CHECK your timming belt for wear and tear, I'm just short of 76k now, is it maybe an idea to change it soon?
6. Got myself a High-visibility Brake light the other day - 2 wires, I split from the break don't I? Is there an earth point near the light cluster in the back?
7. Thick and thin brown cable just under my fuse box - not going anywhere - both with connectors, any ideas? Pics will be available on demmand.
