VAGCOM/VCDS commands compilation
a22tenc
145
Hi, I recently bought a vcds cable on ebay and started fiddling with it. Since this forum doesn't have a dedicated topic for it I decided to create it.
Here I will post many information gathered from some forums and the credits will be on the bottom of the post.
Some tweaks will or not be available on your particular mk5 since there are different versions. I have the first facelift version (2013) so I will write which ones work on mine.
This guide was tested on a Ibiza FR CONNECT 2016
SERVICE
Reset service cycles
With this mod you can reset the maintenance service notification.
1 - Module 17 - Code Box instruments- (25327)
2 - Adaptations
3 - Select - PIM: Restart prolog.interv.mant
4 - Select one of three options:
- No warning (default)
- Active Notice
- Reset
Another way:
1 - Applications
2 - Inspection service reset
3 - Select the desired
Change notice review by KM
With this mod you can reset the warning maintenance service for kilometers.
2 - Adaptation
3 - Select
4 - Fixed: Next máx.hasta mileage rev.en kil function.
5 - Change the desired value. Default 30000
6 - FIXED: resposic value. Próx.inspecc. Depending on the mileage
7 - Change to the desired value. Default 30000
8 - PIM maximum value of KM-delivery kilometric / review
9 - Change the desired value. Default 30000
10 - PIM: minimum value of km-long sandy provision / review
11 - Change the desired value. Default 15000
12 - SIA: value máx.de journey to service
13 - Change the desired value. Default 15000
Change days notice review
With this mod you can reset the maintenance service notice for days.
2 - Adaptation
3 - Select
4 - Fixed: Time má.hsta next rev. Depending on the time
5 - Change the desired value. 730 default d
6 - FIXED: reposic.próx inspecc.en value function of time
7 - Change to the desired value. Default 365 d
8 - PIM maximum value of elapsed time between overhauls
9 - Change the desired value. 730 default d
10 - PIM: minimum value of elapsed time between overhauls
11 - Change the desired value. Default 365 d
12 - SIA: value longer up service
13 - Change the desired value. Default 365 d
Alarm
Activate Alarm Free
No installation required. Suitable for all vehicles without standard alarm. Vehicles without alarm installed. It only monitors doors, bonnet and trunk.
1 - Module 09 - Electronic control unit. Code (31347)
2 - Extended coding (bytes)
3 - Byte 12
4 - Activate Bit 0 (Anti-theft system installed / active)
5 - Adaptation
6 - Submenu - Anti-theft protection
7 - DWA Alarmverzoegerung (Change value to "door contact thatcham driver")
8 - DWA Camper Modus (Change value to "enabled")
9 - Ueberwachung Innenentriegelungshelbel (Change value to "activated")
10 - Akustischer Alarm Signalhorn (Change value to "enabled")
11 - Submenu - Answer Signals
12 - Akustische Rueckmeldung global (Change value to "enabled")
13 - Akustische Rueckmeldung Signalhorn (Change value to "activated")
Note that once we leave the vehicle, the alarm is activated after a few seconds, so if the
We want to try to wait a few seconds and then open the door from the inside (with the window open, for
example). Lock the car while inside, and after about 30 seconds open the door and
The alarm goes off, it switches off or gives the contact or the remote control giving it to open.
Disable beep when you open a door with ignition on
With this mod the warning beep gives to have the ignition and open the driver's door or other doors off.
2 - Adaptation
3 - Select - On active message, exciter
- Driver's door (default)
- All doors
- No indication
Beep / alarm when locking and unlocking the car
With this mod you may have to close, open or in both cases with horn beep occurs.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Signs response
4 - Sub - Akustische rueckmeldung entriegeln --- On
5 - Sub - Akustische rueckmeldung verriegeln --- On
6 - Sub - Global rueckmeldung --- On Akustische
7 - Sub - Akustische rueckmeldung Signalhorn --- On
8 - Sub - Menuesteuerung Akustische rueckmeldung --- On (On Screen Display)
9 - Sub - Dauer der vom akustischen rueckmeldung einfachhorn --- Normal (No alarm) or Kurz (with alarm)
Different beeps Seatbelt
With this mod you can change warning sounds coming from the factory classic American (Various acute Ding and pause)
2 - Extended Coding (Text mode)
3 - Select - Notice for the use of seat belts
4 - Select one of the options:
- Option 1 (default)
- Variant 2
- Off
MULTIMEDIA
Input gain control RADIO FM, AM, DAB, SAT
With this mod you can change the antenna gain.
1 - Module 5F - Electronic Information 1. Code (20103)
2 - Adaptation
3 - Select - Amplify audio input Management Generation 2
4 - Change desired values ​​- By default -128db
Hide / Show band RADIO AM
Lately almost all Lions come without the AM band active. With this mod you'll enjoy it.
3 - Byte 14 AM Disable
4 - Select between two options:
- Enabled (default) The hidden
- Not activated (Sample)
Adjusting the microphone sensitivity
If you think your microphone not also catches your voice, you can make it more responsive making this mod.
2 - Adaptation
3 - Select - Microphone Sensitivity
4 - Change the desired value. Default 0 db
Enable / Disable eject CD / DVD
With this mod you can unlock or lock the eject button on the CD / DVD
2 - Adaptation
3 - Select - Key CD ripping
4 - Select one of the two options:
- Unlocked (default)
- Locked
Enable AUX IN (USB + AUDIO MODULE)
With this mod you can activate or deactivate the AUX input (Pin Jack next US
2 - Extended Code (Text mode)
3 - Byte 8 AUX-IN
- On (default)
- Off
USB input change behavior
With this mod you can change the behavior of USB, IPOD, or just Full load mode even disable it.
3 - Byte 19 USB
4 - Select one of four options:
- USB-IPOD (default)
- Off
- Charge
- Full
Add external sources
With this mod you can add several USB
2 - Adaptation
3 - Select - Interface for external media activation
- Connection 1
- Connection 2
- Connection 3
- Connection 4
AIR CONDITIONING
More cold in the cooler
With this mod 30% more cold in the climate control is achieved.
1 - Module 08 - Electronic air conditioning / heating
2 - Extended Coding (Text)
3 - Temperature Adjustment
4 - Change value: Set colder func.refrig
Show climate control fan speed with LEDs in AUTO mode
As you know, in manual mode the speed segments are led us indicating the fan speed, however they are not automatic. With this mod the it'll also show in automatic mode.
1 - Modulo 08 - Air conditioning / heating electronics
3 - Byte 8
4 - Activate Bit 0
Heating time of the windscreen
With this mod, you can change the time that warming in the front window is active.
2 - Adaptation
3 - Select - Heating crystals
4 - Sub - Running time of heated front window
5 - Change value to 240s
Heating time of the rear window
With this mod, you can change the time that warming in the rear window is active.
2 - Adaptation
4 - Sub - Heckscheibenheizung zeitwert
5 - Change value to 600 s
Automatic activation for wind defrost
With this mod, to start the car if the conditions are right cold start the air conditioner blowing the windscreen defrosting default.
2 - Adaptations
3 - Select - Activa. Autom. Calefacc. Windshield deicing MAX
4 - Change value to On
Modify grades warning of possible danger ice
With this mod, you can change temperatures warning of possible danger of ice.
2 - Adaptation
3 - Select - Outside temperature
4 - Search option - P exit temperature ice warning
5 - Modify the desired value: 6 ° C Default
6 - Search option - P ice warning entry temperature:
7 - Modify the desired value: 4 ° C Default
Heating Mirrors and Windows in Case Of Freeze
Select Control unit 09 (Central Electrics)
Control unit Long Coding
Byte 14
Bit 3-Bit 4 Activate
WINDOWS / MIRRORS
Disabling comfort windows opening from the door lock
With this mod we can deactivate that they go down and that they raise the windows with the key in the door lock.
It is very interesting because it has been proven that in some cases with any key of the group can be lowered and open windows by turning it in the lock.
In no case with a key other than the car opens, but we have also detected that if it can be closed.
2 - Adaptation
3 - Access control 2 - Options (Various values)
4 ------ Schliesszylinder komfort oeffnen - Options (Activated - Inactive)
5 ------ Schliesszylinder komfort schliessen - Options (Activated - Inactive)
Semi-automatic folding and unfolding mirrors
With this mod, holding down the button on the remote can fold or unfold the mirrors to lock or unlock the car.
1 - Electronic control module 09-. Code (31347)
2 - Adaptation
3 - Select - Control Access 2
4 - Sub - Funk modus spiegelanklppung
5 - Change value via remote control Convenience key opeation
Hold the button to fold or unfold
Automatically lock mirrors on locking. (Both via AB and key in door) tested: 2016 model
With this adjustment, the mirrors automatically lock in when the car is locked. If you lock through AB, you do not have to hold down the lock button.
Use this function icm the following function so that you save the mirrors during freezing.
2 - Adaptation
4 - Sub - Funk modus spiegelaklappung
5 - Verander waarde By command via remote control look key
OPTION IN BOARD COMPUTER: Automatic locking of mirrors on locked on / off tested: 2016 model
With this adjustment, you choose whether to turn the mirrors on or off automatically via the on-board computer
2 - Adaptation
3 - Select - Access control 2
4 - Submenu - Menuesteuerung funk spiegel anklappen - Options (Inactive - Activated)
5 - Verander waarde naar On
De menuoptie is nu zichtbaar in het CAR-setup menu.
Opening and closing the windows comfort
With this modification will get the opening and closing windows in comfort mode.
2 - Adaptation
4 - Sub - Comfort opening
5 - Change value to Active
6 - Sub - Menuesteuerung konfortbedienung einstellbar
7 - Change value Adjustable
8 - Sub - Funk konfort oeffnen
9 - Change value to Active
10 - Sub - SAD konfort oeffnen
11 - Change value to Active
12 - Sub - Comfort closing
13 - Change value to Active
14 - Sub - Funk konfort schliessen
15 - Change value to Active
16 - Sub - SAD konfort schliessen
17 - Change value to Active
Activate windows with running even opening the doors so they do not stop
With this mod, the windows work even with the doors open.
2 - Adaptation
3 - Select - Functions assist light
4 - Select - Control Access 2
5 - Sub - FH Freigabenachlauf bei tueroeffnen abbrechen
6 - Change value to On
Permanently disable comfort rear wiper system
If you do not like that every time you back up the rear wiper is started with this mod you can disable it.
2 - Adaptation
3 - Select - wiper
4 - Sub heck -Traenenwischen
5 - Change value on off
Rear wiper setting in the menu
This mod adds more function in the menu of the clean. You can choose to or not activate the automatic rear clean.
2 - Adaptation
3 - wiper
4 - Menuesteuerung konfortwischen HW
5 - Change value to On
Continuing on 2nd post.
Reactions: Vaios_Greece
a22tenc
145
Interior Lighting
Lighting intensity leds AACC / Climate
With this mod, you can change the intensity of illumination in the area of ​​climate control.
2 - Adaptation
3 - Select - Dimming_characteristic_2 (LED indicator)
4 - Change value Y4 21%
5 - Select - Dimming_characteristic_3 (LED fan)
6 - Change value Y4 12%
7 - Select - Dimming_characteristic_5 (Other LEDs)
8 - Change value Y4 10%
Footrest Light
This modification is for those who have the light of the footrests and put it on your own, be activated.
2 - Adaptation
3 - Select - Leuchte30FR LC72
4 - Sub - Lichtfunktion E 30
5 - Change value to Interior Light
Ambient light blank door with reverse only Leon ?
With this mod, carrying the doors in red, when putting the reverse gear will go blank.
2 - Adaptation
3 - Select - Leuchte16BLK SLB35BLK SL KC9
4 - Submenu - Lichtfunktion G 16
5 - Change value to Rückfahrlicht
6 - Select - Leuchte16BLK SLB35BLK SL KC9
7 - Submenu - Dimmwert GH 16
8 - Change value to 0
9 - Select - Leuchte16BLK SLB35BLK SL KC9
10 - Submenu - Dimming direction GH 16
11 - Change value to Minimize
12 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
13 - Submenu - Lichtfunktion C 17
14 - Change value to Rückfahrlicht
15 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
16 - Submenu - Dimmwert CD 17
17 - Change value to 127
18 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
19 - Submenu - Dimming direction CD 17
20 - Change value to Maximized
NOTE: Leuchte 16 is the red light (0 and minimized = 127 and maximized) and Leuchte 17 is white light (0 and minimized = 127 and maximized)
Ambient door light with flashing and color change only LEON?
With this mod, bringing the doors in red, when flashing, the door on the side of the indicator flashes between red and white.
2 - Adaptation
4 - Submenu - Lichtfunktion C
5 - Change value to Blinken links (beide Phasen) BOTH SIDES OF INTERMITTENT or Blinken links (Hellphase) ONLY WITH INTERMITTENT LEFT
7 - Submenu - Dimmwert CD
10 - Submenu - Dimming direction CD
12 - Select - Leuchte16BLK SLB35BLK SL KC9
13 - Submenu - Lichtfunktion E
14 - Change value to Blinken rechts (beide Phasen) BOTH SIDES OF FLASHLIGHTS or Blinken rechts (Hellphase) ONLY WITH RIGHT INTERMITTENT
15 - Select - Leuchte16BLK SLB35BLK SL KC9
16 - Submenu - Dimmwert EF
17 - Change value to 0
18 - Select - Leuchte16BLK SLB35BLK SL KC9
19 - Submenu - Dimming direction EF
20 - Change value to Minimize
21 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
22 - Submenu - Lichtfunktion A
23 - Change value to Blinken links Hellphase
24 - Select - Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
25 - Submenu - Lichtfunktion B
26 - Change value to Blinken rechts Hellphase
Enable indicator Rear fog
With this modification we can visualize in the box snitch when we put the rear lights.
2 - Extended coding (Mode Bytes)
3 - Byte 7
4 - Enable Bit 4
Exterior Lighting
Turn off the daytime running lights (DRL) with the parking brake
This modification is very interesting because it allows us to leave day lights (DRL) off while we have the hand brake with and without contact. Very useful in low battery.
2 - Adaptation
3 - Select - Daytime Running Light
4 - Sub - Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten
5 - Change value to ON
Turn off daytime running lights (DRL) with light selector switch in position 0
This change is also very interesting because it allows you to leave the day off lights while wearing the light switch in zero position. It is compatible with the previous one.
2 - Adaptation
4 - Sub - Tagfahrlicht nur in Schalterstellung AUTO
Eliminate error LED lamps on the license plate
If you are thinking of putting leds on the license plate, this will avoid modification of the Fis you notice defective bulb.
2 - Adaptation
3 - Select - Leuchte25KZL HA59
4 - Sub - Lasttyp 25
5 - Change value Allgemeine LED. 2 * default 5W
6 - Select - Leuchte25KZL HA59
7 - Sub - Dimmwert AB 25
8 - Change value to 127. Default 100
Remove error by mounting of LED lamp in front fog lamps
If you are thinking of putting LED on the front lights, with this modification you will avoid the mistake of bulb failure.
2 - Adaptation
3 - Select - Leuchte13NL RB5
4 - Sub - Lassttyp 13
5 - Change value LED Lichtmodul
6 - Sub - Dimmwert AB 13
8 - Select - Leuchte12NL LB45
9 - Sub - Lassttyp 12
10 - Change value LED Lichtmodul
11 - Sub - Dimmwert AB 12
12 - Change value to 127
Change number of flashes of intermittent comfort
Very interesting for those who believe that comfort intermittent mode fall short with 3 flashes. The maximum value is 5 blinks.
2 - Adaptation
3 - Select - Control of intermittent
4 - Sub - Komfortblinken blinkzyklen
5 - Change to the desired value - Maximum 5
6 - Reset factory settings on the screen lights Car
OPTION IN BOARD COMPUTER: Activate / deactivate daytime running lights(DRL) via CAR-setup menu
With this adjustment, you can switch daytime running lights through the CAR-setup menu.
2 - Adaptation
4 - Sub - Tagfahrlichtnur Aktivierung oder durch BAP Bedienfolge moeglich
5 - Verander waarde naar ON
Long flash burst together with the fog lamps
With this change each time you press the burst in the lights of your car, will light while the front fog lights.
2 - Adaptation
3 - Select - Leuchte12NL LB45
4 - Sub - Lichtfunktion c 12
5 - Change value to Left high beam
6 - Select - Leuchte12NL LB45
7 - Sub - Dimmwert DC 12
8 - Change value to 100
9 - Select - Leuchte12NL LB45
10 - Sub - D 12 Lichtfunktion
11 - Change value to Lichthupe generell
12 - Select - Leuchte12NL LB45
13 - Sub - Dimming direction DC 12
14 - Change Value to Maximize
15 - Select - Leuchte13NL RB5
16 - Sub - Lichtfunktion c 13
17 - Change value Right high beam
18 - Select - Leuchte13NL RB5
19 - Sub - Dimmwert CD 13
20 - Change value to 100
21 - Select - Leuchte13NL RB5
22 - Sub - D 13 Lichtfunktion
23 - Change value to Lichthupe generell
24 - Select - Leuchte13NL RB5
25 - Sub - Dimming direction CD 13
26 - Change Value to Maximize
Activate front fog lamps when reversing
With this mod, when engaging reverse the front fog lights come on.
2 - Adaptation
3 - Select - static cornering light
4 - Sub - Bei rueckwaertsfahrt
5 - Change value to OFF
Deactivate the interior light when opening the trunk
With this change we will make the interior lights of the cabin is not light up when opening the boot.
2 - Adaptation
3 - Select - Interior lighting
4 - Sub - Innenlicht bei offenem heckdeckel einschalten
5- Change value to Off
Enable third brake light when you open the trunk
With this modification, the third brake light turns on when you open the trunk.
2 - Adaptation
3 - Select - Leuchte22BR MA57
4 - Sub - Lichtfunktion C 22
5 - Change value to Heckdeckel Offen
6 - Sub - Dimmwert CD 22
7 - Change value to 100
Enable DRL on front fog lamps
With this modification the fog lights will come on together with the DRL to carry on.
2 - Adaptation
4 - Sub - Lichtfunktion B 12
5 - Change value Daytime Running Lights
6 - Select - Leuchte13NL RB5
7 - Sub - Lichtfunktion B 13
8 - Change value Daytime Running Lights
DRL intensity (Halogen and Bi-Xenon Basic)
With this change we can adjust the intensity of the lights day as we like, considering that default come to 100 and the maximum value is 127.
2 - Adaptation
3 - Select - Leuchte4TFL LB4
4 - Sub - Dimmwert AB 4
5 - Change the desired value. Default 100
6 - Select - Leuchte5TFL RB32
7 - Sub - Dimmwert AB 5
8 - Change to the desired value. Default 100
127 maximum allowed
DRL intensity lights dimmed mode (Halogen and Bi-Xenon Basic)
With this modification the DRL is gradually attenuated in the switching on and off.
2 - Adaptation
4 - Sub - Dimmwert EF 4
5 - Change the desired value. By default 40
7 - Sub - Dimmwert EF 5
8 - Change to the desired value. By default 40
127 maximum allowed
Intensity lights DRL LED lights
2 - Adaptation
3 - Select - Leuchte2SL VLB10
4 - Sub - Dimmwert CD 2
5 - Change the desired value. Default 26
6 - Select - Leuchte3SL VRB21
7 - Sub - Dimmwert CD 3
8 - Change to the desired value. Default 26
127 maximum allowed
Flashing DRL Simultaneous with bi-xenon headlights Basic
2 - Adaptation
4 - Sub - Lichtfunktion C4
5 - Change value to Not active
6 - Select - Lichtfunktion C 5
7 - Change value to Not active
Flashing lights DRL with LED simultaneous
2 - Adaptation
4 - Sub - Lichtfunktion G 2
5 - Change value Blinken links Dunkphase
6 - Select - Leuchte2SL VLB10
7 - Sub - Dimmwert GH 2
9 - Select - Leuchte2SL VLB10
10 - Sub - Dimming direction GH 2
12 - Select - Leuchte3SL VRB21
13 - Sub - Lichtfunktion G 3
14 - Change value Blinken links Dunkphase
15 - Select - Leuchte3SL VRB21
16 - Sub - Dimmwert GH 3
17 - Change the desired value
18 - Select - Leuchte3SL VRB21
19 - Sub - Dimming direction GH 3
Activate Coming & Leaving Home in fog lights
2 - Adaptation
3 - Select - Lighting comfort
4 - Sub - Coming home leuchten
5 - Change value to Fog light
Enable fog cornering (cornering function)
If your car does not carry activated the fog lights turn on curves, with this modification you can activate this feature.
2 - Adaptation
4 - Sub - D 12 Lichtfunktion
5 - Change value to Abbiegelicht links
7 - Sub - Dimming direction DC 12
8 - Change Value to Maximize
10 - Sub - Dimmwert DC 12
11 - Change value to 100
12 - Select - Leuchte13NL RB5
13 - Sub - D 13 Lichtfunktion
14 - Change value to Abbiegelicht rechts
16 - Sub - Dimming direction CD 13
17 - Change Value to Maximize
Zie volgende post voor vervolg
Regulation of lights or turn corner
With this modification you can change the speed at which you want them to act the cornering. By default come to 40 km / h.
2 - Adaptation
3 - Select - static curve light
4 - Sub - Untere geschwindigkeitsschwelle
6 - Sub - Obere Geschwindigkeitsschwelle
7 - Change value to 60. Default 40 Km / h
Turn off lights or turn corner
With this modification you can disable cornering function.
2 - Adaptation
3 - Select - Leuchte12NL LB45 (Left)
4 - Sub Lichtfunktion B 12
5 - Change value to Not Active
6 - Select - Leuchte13NL RB5 (Right)
7 - Sub Lichtfunktion B 13
8 - Change value to Not Active
Automatic activation Coming & Leaving Home
With this modification the Coming and Leaving Home system is automatically activated.
2 - Adaptation
4 - Sub - Coming home verbaustatus
5 - Change value to Automatic
Activate Coming Home without light rain sensor
If you do not have rain sensor you can also activate the Coming Home with this modification.
2 - Adaptation
4 - Sub - Coming Home Verbaustatus
6 - Sub - Menueeinstellung cominghome
7 - Change default value 20.Por 10 s
8 - Sub - Coming home Einschaltereignis
9 - Change value to Driver door
10 - Sub - Menuesteuerung coming home Werkseinstellung
11 - Change value to On
12 - Sub - Coming home leuchteng
13 - Change value Low beam
Coming Home & Leave Home - Include cornerings
With this modification you can include the cornerings to coming home and leave home.
2 - Adaptation
3 - Select - Leuchte8FL LB39
4 - Sub - Lichtfunktion H8
5 - Change value to leaving home Coming home oder aktiv
6 - Select - Leuchte8FL LB39
7 - Sub - Dimming direction GH 8
9 - Select - Leuchte8FL LB39
10 - Sub - Dimmwert GH 8
11- Change value to 100
12 - Select - Leuchte9FL RB2
13 - Sub - Lichtfunktion H9
14 - Change value to leaving home Coming home oder aktiv
15 - Select - Leuchte9FL RB2
16 - Sub - Dimming direction GH 9
18 - Select - Leuchte9FL RB2
19 - Sub - Dimmwert GH 9
a22tenc
145
coming home & leave home alone drl, without beam (halogen / xenon)
with this modification, only the drl will be active in the coming and leaving home.
1 - module 09 - electronic. Code (31347)
2 - adaptation
3 - select - leuchte6abl lc5
4 - sub - lichtfunktion c6
5 - change value to leaving home coming home oder aktiv
6 - select - leuchte6abl lc5
7 - sub - dimming direction cd 6
8 - change value to minimize
9 - select - leuchte6abl lc5
10 - sub - dimmwert cd 6
11 - change the desired value
12 - select - leuchte7abl rb1
13 - sub - lichtfunktion c 7
14 - change value to leaving home coming home oder aktiv
15 - select - leuchte7abl rb1
16 - sub - dimming direction cd 7
17 - change value to minimize
18 - select - leuchte7abl rb1
19 - sub - dimmwert cd 7
20 - change the desired value
coming home & leave home with led drl lights + xenon
with this modification drl + xenon + fog lights are active in the coming and leaving home.
2 - adaptation
3 - select - lighting comfort
4 - sub - coming home leuchten
5 - change value to fog lights
6 - select - leuchte12nl lb45
7 - sub - lichtfunktion e 12
8 - change value oder coming home leaving home aktiv
9 - select - leuchte12nl lb45
10 - sub - dimmwert ef 12
coming home & leave home also third brake light
with this modification, the third brake light is active in the coming and leaving home.
2 - adaptation
3 - select - leuchte22br ma57
4 - sub - lichtfunktion b 22
coming home & leave home also inside. Led drivers
2 - adaptation
3 - select - leuchte27nsl rc6
4 - sub - lichtfunktion b 27
coming home & leave home also inside. No led drivers
2 - adaptation
3 - select - leuchte24sl hra65
4 - sub - lichtfunktion b 24
6 - select - leuchte23sl hlc10
7 - sub - lichtfunktion b 23
8 - change value to leaving home coming home oder aktiv
activate coming home to open the driver's door
with this modification, the coming home can be activated when you open the driver's door.
2 - adaptation
4 - sub - coming home einschaltereignis
5 - change value to drivers door
parking light position also inside. No led car drivers closed
2 - adaptation
3 - select - leuchte23sl hlc10
4 - sub - lichtfunktion h 23
5 - change value to parklicht links
7 - sub - dimming direction gh 23
8 - change value to maximize
9 - select - leuchte23sl hlc10
10 - sub - dimmwert gh 23
11 - change value to 28
12 - select - leuchte24sl hra65
13 - sub - lichtfunktion h 24
14 - change value parking light right
15 - select - leuchte24sl hra65
16 - sub - dimming direction gh 24
17 - change value to maximize
18 - select - leuchte24sl hra65
19 - sub - dimmwert gh 24
20 - change value to 28
parking light position also inside. Car led drivers closed
2 - adaptation
5 - change value parking light right
fog lights with cornering together to put intermittent
2 - adaptation
3 - static cornering light
4 - sub - vorschrift
5 - change value to fmvss 517 108. By default ece r119
activate tail light (gate) to open the trunk. (led drivers)
with this modification to open the trunk, lights that go in the gate will light ..
2 - adaptation
4 - sub - hd lichtansteuerung ab 23
5 - change value to always
6 - select - leuchte24sl hra65
7 - sub - hd lichtansteuerung ab 24
8 - change value to always
2 - adaptation
3 - select - leuchte26nsl la72
4 - sub - hd lichtansteuerung ab 26
6 - select - leuchte27nsl rc6
7 - sub - hd lichtansteuerung ab 27
8- change value to always
turn on led rear lights together with drl
with this adjustment, the rear led lights automatically switch on when switching on drl illumination.
2 - adaptation
3 - select - daytime running light
4 - sub - tagfahrlicht dauerfahlicht aktiviert zusaetzlich standlicht
5 - verander waarde naar on
activate rear fog with the trunk open. (no led drivers)
with this modification we can make the rear fog lights turn on when you open the trunk.
2 - adaptation
red light in all driving modes
with this modification, the lights of the doors will always be red in all driving modes.
2 - adaptation
3 - select - leuchte17tfl srb3tfl r r blk blk sr kc3
4 - sub - lichtfunktion a 17
5 - change value to off
6 - select - leuchte16blk slb35blk sl kc9
7 - sub - lichtfunktion b 16
8 - change value to environmental luz 3
drl against appr phase with bi-xenon front lights and halogen
with this modification you can make do the following: When the flashing light drl are off and when the indicator is off the drl light. It is very cool.
2 - adaptation
3 - select - leuchte4tfl lb4
4 - sub - lichtfunktion c4
5 - change value not active
6 - select - leuchte4tfl lb4
7 - sub - dimmwert gh 4
8 - change to the desired value
9 - select - leuchte4tfl lb4
10 - sub - lichtfunktion g 4
11 - change value blinken links hellphase
12 - select - leuchte4tfl lb4
13 - sub - dimming direction gh 4
14 - change value to minimize
15 - select - leuchte5tfl rb32
16 - sub - lichtfunktion c 5
17 - change value not active
18 - select - leuchte5tfl rb32
19 - sub - dimmwert gh 5
21 - select - leuchte5tfl rb32
22 - sub - lichtfunktion g 5
23 - change blinken value rechts hellphase
24 - select - leuchte5tfl rb32
25 - sub - dimming direction gh 5
26 - change value to minimize
against stage lights drl with led lights appr forward
2 - adaptation
3 - select - leuchte2sl vlb10
4 - sub - lichtfunktion g 2
5 - change value blinken links hellphase
6 - select - leuchte2sl vlb10
7 - sub - dimmwert gh 2
9 - select - leuchte2sl vlb10
10 - sub - dimming direction gh 2
11 - change value to minimize
rear lights flashing in sequence mode (led drivers)
2 - adaptation
3 - select - leuchte16blk slb35blk sl kc9
4 - sub - lichtfunktion a 16
6 - select - leuchte17tfl srb3tfl r r blk blk sr kc3
7 - sub - lichtfunktion a 17
8 - change value blinken links hellphase
system
sensitivity hill start assistant
we can modify the way the wizard acts hill start adapting to our needs or habits.
1 - module 03 - electronic brake. Code (40168/20103)
2 - adaptation
3 - select - start assist slope
4 - activate one of the three options:
- normal (default)
- advance
- time delay
tilt hill start assistant
with this modification we can change when we want to be activated depending on the steepness of the slope.
2 - adaptation
3 - select - start assist slope, slope limit
4 - change the value you want.
A higher value more inclination required for activation
default 3%
disabling pending support assistant
with this modification we can cancel the pending help system.
2 - extended coding
3 - byte 16
4 - enable bit 0
expanded xds electronic differential lock
we may change the way it works, you can choose between several values ​​in a way that best suits our driving.
2 - adaptation
3 - select - electronic differential lock expanded
4 - activate one of the five options:
- standard (default)
- central
- not activated
- weak
- strong
esp depending on the speed
applying this modification can activate the esp function acting on the speed that take the vehicle or the value is always fixed.
2 - adaptation
3 - select - electronic stability program
4 - select one of the two options:
- activation function of speed
- not enabled (default)
- activated
disable esp and asr
with this modification permanently dasactiva the esp. I do not recommend it, i do not like.
2 - basic settings
3 - select - deactivation esp and asr
- activated
activate the warning of speeding and at what speed
with this modification you can activate the speed warning and at what speed. It can be done on the screen.
1 - module 17 - code box instruments- (25327)
2 - extended coding
3 - byte 0
4 - enable bit 6
another way :
1 - adaptation
2 - select - speed ​​warning
3 - select one of the two options:
- activated
- off (default)
4 - change value in kilometers per hour to the desired
enable display driver profiles at startup
if your car is driving profiles, with this mod, every time you boot it will show in the fis how you are without having to look at the screen.
1 - module 19 - diagnosis interface for data bus. Code (20103)
2 - extended coding (byte mode)
3 - byte 8
4 - activate bit 4
direct acceleration - throttle response
with this mod, you can change the behavior of the accelerator. Option b provides a more linear acceleration without sudden deliveries.
1 - module 44 - power steering. Code (unknow)
2 - adaptation
3 - select - switching driving profile
choices :
A - gradual, controlled by time
b - directly controlled threshold value
driver profile - driving modes
with this mod, you can change the behavior of the car, in dynamic mode behaves somewhat more cheerful in the reactions.
2 - adaptation
3 - select - lines features power steering
choices :
- button for selecting the driving profile
- comfort
- dynamic
- automatic
- default
drying the brake discs
our cars have a brake drying system which acts each time you start the car for a fixed time.
2 - adaptation
3 - select - drying brake discs
4 - activate one of four options:
- central (default)
- not activated
- weak
- strong
reset settings tires
if you take time with your car and you were adjusting the pressure and want to adjust them to the factory settings, you can do so using this modification.
2 - basic settings
3 - select - rest. Factory settings control indicator tires
4 - select the desired option
- activated
disable mode transport
2 - adaptation
3 - mode of transport
- off (default)
- activated
dynamic adaptation brake release
with this mod, we can make our vehicle snatch a little more to the rally. Strong default being prevents wheel spin at the start.
1 - module 03 - brake electronics. Code (40168/20103)
2 - adaptation
3 - anti-skid control in acceleration - options: (on - not activated)
4 - motor drive torque adjustment - options: (activated - not activated)
dashboard
test needle / staging mode when the ignition
with this mod, by making contact makes the staging or test needle, is a very striking mod.
2 - extended coding
3 - byte 1
4 - enable bit 0
chronometer in fis \ laptimer!
with this mod, you will add a timer in the fis.
2 - extended coding
3 - byte 1
4 - enable bit 3
fis liters refueled
with this mod, you will add the function of liters you have to refuel.
2 - extended coding
3 - byte 10
4 - enable bit 4
it shows the liters of 5 in 5. Full deposit = 45 liters, full tank shows three stripes.
disable seat belt warning
with this mod, you can disable the audible and visual warning belts.
2 - extended coding
3 - byte 1
4 - disable bit 1
another way :
1 - adaptation
2 - select - disable belt warning
- no (default)
- yes
fis oil temperature ->by default in fr
with this mod, you add the oil temperature in the fis
1 - box module 17- instruments- code (25327)
2 - extended coding
3 - byte 10
4 - enable bit 1
another way :
1 - adaptation
2 - select - display of oil temperature
- yes (default)
- do not
fis compass (bearing browser)
with this mod, you will add the compass in the fis (only if you have other browser)
2 - extended coding
3 - byte 10
4 - enable bit 6
another way :
1 - coding extended (text mode)
2 - navigation / compass - switch to si
3 - indicator compass --- lower position (change what you want)
digital odometers in fis
with this mod, you add the digital speedometer in the fis (you have to select it on the screen of settings)
3 - adaptation
4 - select - digital tachometer
5 - select one of three options:
- indication
- no indication
- not available
personal consumption adjustment display fis
with this mod, you can calibrate consumption if you see that do not fit what you think.
2 - adaptation
3 - select- correc.del indic.de consumption / combustion scope - options: (100%)
4 - change value. Default 100%
5 - the adjustment allows increments of 1%, maximum and minimum values ​​are 85 (%) and 115 (%).
a22tenc
145
Activate carbon background Infotainment
With this mod, change the background screen infotainment to Carbon mode.
3 - Byte 17 Skinning
4 - Select Skin 3
Change Home Screen
With this mod, we change the screen that starts the infotainment.
3 - Select - Initial Screen
4 - Select one of eight options
- Rest
Activating Driving Mode menu Car / CAR
With this mod, we activate a new screen infotainment. driving school mode. It is a pijada, does not show too much,
2 - Adaptation
3 - Select - Car Function Adaptations Gen 2
4 - Search submenu - Menu display driving school
6 - Without leaving the submenu search - Menu display driving school over threshold
7 - Change value to ON
8 - Select - Car List Function CAN Gen 2
9 - Search submenu - Driving school
10 - Change value Available
11 - Search submenu - Driving school bus msg
12 - Change value comfort databus
DRL control from the CAR menu
With this mod, we activate a new option in Settings-lights where we can activate or deactivate the DRL.
2 - Adaptation
3 - Daytime Running Light
4 - Tagfahrlicht Aktivierung oder durch BAP bedienfolge moeglich
Change radio logo (FR, Cupra, Ecomotive)
With this mod, you can change the initial logo.
1 - Module 5F - Information Electronics 1. Code (20103)
2 - Adaptation
3 - Byte 18 Screenings
Value in 0 - Seat Normal
Value in 1 - Seat FR
Value in 2 - Seat Cupra
Value in 3 - Seat Ecomotive
Value in 5 - Seat Xperience
Value in 6 - Seat FR Line
Rear wiper on screen
With this mod, we activate the comfort mode back clean
2 - Adaptation
3 - wiper
Engineer mode or Green Menu
With this mod, we activate the engineer mode. Vallais be careful not to roll.
2 - Select CHANGE SERVICE
3 - development mode.
4 - Adaptation
5 - Development Mode
6 - Change to On.
- Restart Infotainment
- Hold the Menu button and hold until you exit the menu updates and not let go until you exit the menu engineer.
Change system language
With this mod, we can change the system language.
2 - Adaptation
3 - Select - Language
4 - Select language
Menu Display Compass - OFF ROAD WITH AND WITHOUT NAVI
2 - Adaptation
4 - Search submenu - Menu compass display (ON)
5 - Search submenu - Menu display compass over threshold (ON)
6 - Select - Car Function List Bap Gen 2
7 - Search submenu - Compass 0x15 (ON)
8 - Search submenu - 0x15 Compass msg bus (data bus comfort)
9 - Byte 24 Navigation System
10 - Change value to On.
This mod does not allow all functions without NAVI.
Logically altitude and compass does not display data.
Also reports a fault in the module 5F saying that environmental data missing
(Only reports to do analysis with OBDeleven, nothing comes on screen)
A normal error and do not have to worry.
With NAVI everything works 100%
If you want me to show the angle of rotation of the wheels on this menu you have to make the mod Slope Angle of View menu.
Menu Display Angle of Slope - angle of rotation of the wheels
With this modification you can add new functionality to Mod OFFROAD Display Menu.
By itself does not work, you must have activated the OFFROAD menu.
We will show graphically the angle of rotation of the wheels to turn the wheel.
2 - Adaptation
4 - Search submenu - Menu display angle of stope (ON)
5 - Search submenu - Menu display angle of stope over threshold (ON)
7 - Search submenu - Angle of stope 0x24 (ON)
8 - Search submenu - 0x24 Angle of stope msg bus (data bus comfort)
Displays temperature
With this mod we can change emperature degrees Celsius to Fahrenheit
3 - Extended Coding
4 - Temperature
5 - Select one of the two options:
- Celsius degrees
- Fahrenheit degrees
Install OEM Rear Camera
Necessary items: OEM NTSC camera, connectors for the Quadlock.
Install the camera by connecting the original cables of the ceiling to the cables of the light of the new ceiling.
Feed the camera directly from the cigarette lighter or from fuses.
Connect the signal cables to the Quadlock (Blue Connector) Where the PIN 6 is the positive and the PIN 12 is the video mass.
1 - Module 5F
2 - Coding (bytes mode)
3 - Byte 19 - Activate bit 4
Another way:
1 - Coding (text mode)
2 - Byte 19 Rear View Low --- Set it to On
Set / Disable Sound Generator Only Available on Cupra Models
1 - Aanpassing - Channel 10
2 - IDE04472 -. Volume d actuator voor mechanische trillingen
3 - Environment: 0,0% (Soundgenerator Deactivated) - Alternative
: elke% Enter - Standard: 100% (% Value refers to sports mode)
4 - Set value refers to the sport mode, in normal mode, the sound generator only works in a certain relation with the individual value (about 1/3 - 50%)
Credits: rikhartman from seat-online.nl
There's also a PDF guide that you can download here.
superf
7
Thessaloniki, Greece
Well done!
This is a great guide!
I own a SEAT Ibiza FR 2016 with twin halogen headlights and DRL LEDs. I'm trying to find a way that the DRL Leds stay on all the time even when the low/high beams are on.
The standard mode is:
Switch to 0 --> DRL LEDs on
Switch to side lights --> DRL Leds on
Switch to low/high beams --> DRL LEDs off!
Does anybody have a clue about that?
volkslove
VCDS Error for fuel refill
Hi tried to do this coding but got the following VCDS Error.
Coding rejected
Error 00: Unknown (0X00)
Security code was accepted. Anyone know what this error means?
fis liters refueled
2 - extended coding
3 - byte 10
4 - enable bit 4
it shows the liters of 5 in 5. Full deposit = 45 liters, full tank shows three stripes.​
etpzek
volkslove
Coding rejected
fis liters refueled
2 - extended coding
3 - byte 10
4 - enable bit 4
etpzek
Ok nevermind. Go it sorted. You get that error when the engine is running. Did some digging and found the solution.
Sent from my SM-A520F using Tapatalk
dm222
1,481
49
Is that to optimize the fuel level display?
Because the first half lasts like 75% of the deposit and the second half 25%.
Migi
9
I did a lot of research on how to turn off traction control fully. Did some backwards engineering and figured it out:
Abs brakes -> long code -> byte 22 to DB binary 11011011 -> esc sport -> esc off
OR
11011111 DF -> asr off -> esc off
This will also change the menu automatically. If you are unsure of driving without ESC dont try this. For me the ESC sport tries to kill me a few times when cornering fast
Vaios_Greece
18
8
Hell to everyone! Here goes my question. Is there a coding option to bypass canbus errors for reverse light bulbs ? I've recently replaced my standard bulbs with led ones , and the only canbus error i get is from the one in the reverse . Strangelly enough , the led bulb , pops errors when it's put only in the left rear light. If the same bulb is inserted in the right rear light everything is normal ( no errors , bright led lighting...) . So is there any coding to do in order to fix it ? My Ibiza is a 2015 facelift 6j. Thanks in advance
Vaios_Greece
18
8
Which version of Ibiza?
The LHS "reversing light" in your car will be the rear fog light - no?
Thanks for replying. If a understand your question, is the second facelift ibiza 6j 5door September 2015,which has two reverse lights, one in each side .it also has two rear fog lights one in each side.
Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
RUM4MO
7,966
1,059
South Scotland
Oh! sorry for getting that wrong, I did notice after I posted that that you did write that it was a face lifted version, I'm very surprised that SEAT supplied cars with 2 reversing lights and 2 rear fog lights.
