vagcom serial to PCMCIA converter
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
the serial to usb converter i have been using with my vagcom lead has just broken ( usb bit has broke off) and tbh , i was fed up of it moving about n losing comms etc , and was wondering if anyone uses a PCMCIA - serial converter with any sucess , what should i look for when ordering one , or if possible a direct URL
thanks as always
stephen
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
you could always go down the serial card route (25 pin) with a 25 to 9 pin convertor which is pretty substantial compared to the flimsy usb ports. only thing is you might need two pcmcia port heights to get this card to fit as im not sure by the image if the plastics actually sit outside the enterance of the slot, touch and go.
you could probably ebay the card cheaper too
http://www.maplin.co.uk/Module.aspx?ModuleNo=47115&criteria=pcmcia serial&doy=15m9
http://www.maplin.co.uk/Module.aspx?ModuleNo=10947&criteria=25 To 9 pin convertor&doy=15m9
