vagcom golf 4 differs to seat ibiza
villian
birmingham
Hi.I wonder if any vag-com experts can assist please.After using vag-com on my Golf 4 130 TDI I have bought a 2005 Seat Ibiza fr 130 TDI with 4 door c/locking and 4 power windows.There appears to be a different level of software over the Golf.I am trying to make selective unlocking inactive and going into module 46-central convienience-recode-07 the software coding (top box) reads 00018, I was expecting 00258 or 00256 as with Golfs (4 door p/w). The help pop up box also differs from the Golf, it's as follows on the Seat:-'
00016-central locking without power windows
00064- c/l with 2 p/w (front)
00256- c/l with 4 p/w (front and back)
+00-2 door with selective (single)door locking active
+01-selective single door locking inactive
+02-4 door
Can I assume that 00019 will make the selective locking inactive? (adding 1).Thought I'd ask if anyone has faced this. Other postings suggest that Ibiza owners had similar results/readings to the Golf,ie 00256 or similar.
Many thanks
Theresias
So basically your current coding is 00018? Then that means you have a 4-door model without power windows - thats why your coding is that different from the more common ones. Most Golfs and such have at least front power windows. :) Your calculation (+1) was correct, a coding of 00019 will deactivate the selective locking.
villian
birmingham
Thanks Theresias, job now done 00019 did the trick, but i'm still somewhat :confused: as the car has got 4 doors with 4 door c/l and 4 door p/w but I agree the coding suggests otherwise!
