Bogwoppit
1,085
Lincs
Hello
I recently bought a 2000 Seat ibiza Cupra 20VT, I removed all the seats (carefully unplugging the front seat airbag wires) and used a Vax carpet cleaner on the seats. I then refitted the seats and plugged them back in and I now have an Airbag light on. I understand from previous posts that I should have disconnected the battery before removing my seats this is why the Airbag light is now on. Can anyone in the Lincs area with VAG-COM please help me remove these fault codes.
If not any idea what a dealer will charge?
ive got the cable and vag com on a laptop but they wont likn together if you have a laptop i may be able to loads vag com on to yours and use my cable!
I have tried the battery disconnection and it didn't work.
How long is your vagcom lead gazjones as I have a pc about 2m from the car but alas no laptop?
Assuming it plugs in near the fusebox (MK3 ibiza) 6ft won't quite do it, but thanks anyway. I'll have to see how much Ilkeston Coop Seat or M G Raws will charge.
Thanks for your help gazjones and m0rk.
ok mate sorry i couldnt help shgould only need the fault clearing ill let you know if i get it sorted soon and will be able to help you out
Just to let you know I got my car fixed today by a Local VW specialist M.G. Raw. As we suspected 2 airbag faults were found: interupted power supply on the drivers seat and on the passenger seat, they have been cleared and now my car is fixed.
Thanks guys
glad you got it sorted out where is this vw place my look at using it for some things like fitting and servicing!
i know its a bit late but i ordered a hand held one the other day for future problems, should be here in a few days, let me know if you have anymore problems.
