vag-com logs??
mini_hammy
dirty wee ****er :D
Sep 7, 2008
118
tarbolton,Ayrshire
VAG-COM Version: Release 409.1-S
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01: Engine
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
3 Faults Found:
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
1 Fault Found:
01314 - Engine Control Module
79-00 - Please Check Fault Codes
Address 08: Auto HVAC
Controller: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
No fault code found.
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 6K0 920 901 D
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00442
Shop #: WSC 00000
IMMO-IDENTNR: SEZ7Z0A1353055
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 56: Radio
Controller: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06403
End --------------------------------------------------------------------------------------------------
basically am a right in saying i have a ****ed MAF and abs sensor???
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
reset them first and see if they go away.
log airflow under load (block 002 or 003) to see what airflow you actually get.. 120g/s if stock 150g/s+ if mapped
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
yep.. if reset and they come straight back its likely real.. not sure about the terminal 30 one tho as thats usually after battery off..
how have you been resetting?
R4cup
Beef NO Burger
Jul 28, 2006
1,757
In the garage
Sorry to butt in on your thread mini but i ran some logs on my maf a few days ago and it was pulling a max of 145g/s & its mapped. Should i change my maf?
