VAG-COM logs, please help interpret (NEW POST MAF LOGS NOW INCLUDED)
jonnyblease
141
I have had a few errors when scanning vag-com through my ibiza cupra mk3. The maf signal being too low and engine running too lean. I have now ordered a new MAF from seat and that should arrive in stock today (hopefully).
I was reading through another thread and it suggested some logs to run. so below are some logs please take a look and let me know what you think; (these are before i have changed the MAF i will do the same logs again later once i have replaced the MAF, my understanding is limited of these logs all i can see is that the grams of air per second looks very low for a remapped 1.8t)
Code:
Group A:	'003				Group B:	'020
	RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME					TIME
STAMP	 /min	 g/s	%	 °BTDC	STAMP	 CF	 CF	 CF	 CF
0.5	2800	43.08	31.8	15	0.04	0	0	0	0
1.3	2960	67.22	100	14.3	0.9	3	3	0	3
2.1	3240	84.81	100	7.5	1.7	5.3	3	3	3
2.9	3480	90.72	100	8.3	2.5	5.3	3	3	6.8
3.7	3720	93.17	100	8.3	3.3	5.3	6	6	6.8
4.5	3960	91.47	100	12	4.1	8.3	9	9	9.8
5.3	4160	92.14	100	12	4.9	11.3	9	9	9.8
6.19	4400	94.11	100	12	5.79	11.3	12	9	9.8
6.99	4560	94.97	100	13.5	6.59	11.3	12	12	12
7.79	4720	96.53	100	15	7.39	11.3	12	12	12
8.59	4920	98.75	100	15.8	8.19	11.3	12	12	12
9.39	5040	98.31	100	15.8	8.99	12	12	12	12
10.3	5200	96.81	100	15.8	9.9	12	12	12	12
11.1	5320	96.19	100	15.8	10.7	12	12	12	12
11.9	5440	94.97	100	15.8	11.5	12	12	12	12
12.7	5560	94.11	100	15	12.3	12	12	12	12
13.49	5640	95.72	100	15	13.1	12	12	12.8	12.8
14.29	5720	96.58	100	15.8	13.9	12	12	12.8	12.8
15.09	5840	97.28	100	15	14.69	11.3	11.3	12.8	12.8
15.89	5920	97.47	100	18	15.49	11.3	11.3	12.8	12.8
16.69	5960	98.36	100	17.3	16.29	11.3	11.3	12.8	12.8
17.49	6040	98.69	100	18	17.09	11.3	11.3	12.8	12
Code:
Group A:	'115				Group B:	'031
	RPM	Load	Absolute Pres.	Absolute Pres.		Voltage	Voltage
TIME					TIME
STAMP	 /min	%	 mbar	 mbar	STAMP	 V	 V
0.4	2720	44.4	970	1110	0.06	0.07	0.725
1.2	2840	72.9	1030	1310	0.8	0.135	0.71
2	3040	99.2	1850	1620	1.6	0.11	0.745
2.89	3320	133.1	2420	2280	2.4	0.6	0.315
3.71	3600	134.6	2420	2390	3.29	0.75	0.785
4.61	3920	130.1	2220	2330	4.21	0.75	0.78
5.41	4160	120.3	2130	2150	5.01	0.79	0.815
6.21	4400	117.3	2010	2060	5.81	0.785	0.81
7.01	4600	112	1860	1960	6.61	0.79	0.805
7.81	4840	107.5	1790	1880	7.41	0.785	0.805
8.61	5000	103	1740	1790	8.21	0.795	0.82
9.41	5200	97.7	1710	1710	9.01	0.805	0.825
10.21	5360	94	1700	1680	9.81	0.81	0.825
11.1	5520	91.7	1670	1680	10.7	0.805	0.83
11.9	5640	88.7	1660	1620	11.5	0.805	0.825
12.7	5720	88	1650	1620	12.3	0.81	0.825
13.5	5840	88	1640	1610	13.1	0.825	0.835
14.3	5960	87.2	1610	1600	13.9	0.815	0.83
Code:
Group A:	'118				Group B:	'032
	RPM	Temperature	Load	Absolute Pres.		Lambda	Lambda
TIME					TIME
STAMP	 /min	°C	%	 mbar	STAMP	%	%
0.38	2560	24	69.4	1030	0.78	0	18.8
1.18	2680	24	88.6	1560	1.59	0	18.8
2.07	2920	23	80.8	2100	2.49	0	18.8
2.89	3200	23	86.7	2380	3.29	0	18
3.78	3520	24	83.1	2390	4.18	0	18
4.58	3760	27	82.4	2240	4.98	0	18
5.38	4000	29	81.6	2200	5.78	0	18
6.18	4200	31	78.4	2080	6.58	0	18
6.98	4400	33	78	1980	7.38	0	18
7.78	4600	36	76.9	1930	8.18	0	18
8.58	4760	37	76.5	1880	9.08	0	18
9.59	4960	39	75.3	1810	9.99	0	18
10.39	5120	41	72.9	1740	10.79	0	18
11.19	5240	42	72.2	1740	11.59	0	18
11.99	5400	43	71.8	1720	12.39	0	18
12.77	5520	44	68.6	1650	13.19	0	18
13.59	5640	45	68.2	1640	13.97	0	18
jonnyblease
141
BTW i dont know if i have done suitable logs really i got them from another thread that damegon (think its that) stated to have a go at...
thanks again
jonnyblease
141
It was mapped by star performance, i have just replaced the maf i have done one measure of block 002 and the maf reading look a lot more respectable peaking at 152g/s, (il post the logs ups now)
i dont really understand timing pull, could that have anything to do with the maf?
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
152g/s is about right for a mapped k03 I think. What cf's did you get this time?
A dodgy MAF could of caused it to run lean causing the high cf's..
jonnyblease
141
i haven't managed to do any other logs as i was trying to do them in 4th gear as you said in another thread but its a little busy at the moment for doing any other logs as 6000rpm in 4th gear is quite fast ;)
i will post some up later, on another note VAG-COM did come up with errors previous to changing the maf stating the system was running lean.
BTW did i run the right logs do you want the exact same 6?
thanks alot btw i appreciate it
Jonny
Damoegan
Oct 15, 2007
8,993
Newcastle
Yea, do the same logs again.
You can do them in 3rd too, its just 4th gear is closer to a 1:1 ratio.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
whhhoa bigger cf than mine was.... they are pretty bad mate.
what fuel do you use?
logs you did are good mate. do them in 3rd if its easier. 2.5k to the redline.
boost looks good, actual vs requested.
maf very low for mapped ko3s.
152g/s on new maf is good. relog to see if it sorts timing pull.
jonnyblease
141
thanks guys i am going to do the same logs later on when the bypass is clear of traffic then il get them posted up. Im really hoping that the timing was way out because of the maf (fingers crossed)
I only ever use V power or Tesco Super Unleaded thats what the original logs were on but im at uni and there is no tesco or shell near so i have had to change to BP ultimate 97 :( which is what the second logs will be on.
check back later
thanks again
Jonny
jonnyblease
141
Just done the same logs after fitting the MAF, to me the timing still looks far too high but anyway please post any advice.
Code:
TIME					TIME
0.03	2480	4.17	2.7	25.5	0.4	0	0	0	0
0.8	2440	10.69	8.2	15.8	1.22	3	3	2.3	1.5
1.6	2520	54.14	100	17.3	2	2.3	2.3	1.5	0
2.4	2720	78.39	100	9	2.8	0.8	0.8	0	0
3.2	2960	103.64	100	7.5	3.6	0.8	0.8	0	3
4	3240	117.17	100	12.8	4.4	3	0	3	3
4.8	3480	122.17	100	9.8	5.21	3	3	3	3
5.71	3760	128.33	100	10.5	6.21	6	6	6	6
6.61	4000	131.81	100	12	7.01	6	6	6	6
7.41	4240	136.47	100	13.5	7.81	6	6	6	6
8.21	4440	139.22	100	15.8	8.72	6	9	9	6
9.21	4680	141.28	100	14.3	9.61	8.3	9	9	5.3
10.01	4840	144	100	18.8	10.41	8.3	9	9	5.3
10.81	5000	146.75	100	19.5	11.21	8.3	9	9	5.3
11.61	5160	149	100	18.8	12.11	8.3	8.3	8.3	5.3
12.51	5320	149.75	99.6	15	12.91	7.5	8.3	8.3	5.3
13.31	5440	149.39	100	15	13.71	7.5	8.3	8.3	7.5
14.11	5560	150.33	100	15	14.51	7.5	8.3	8.3	7.5
14.91	5680	150.81	100	15.8	15.31	7.5	8.3	8.3	7.5
15.71	5760	149.47	100	15	16.11	7.5	7.5	7.5	7.5
16.61	5880	152.39	100	15.8	17	6.8	7.5	7.5	7.5
17.52	5960	150.81	100	16.5	17.92	6.8	7.5	7.5	6.8
18.32	6040	151.86	100	18.8	18.72	6.8	7.5	7.5	6.8
19.12	6120	147.64	100	18.8	19.5	6.8	7.5	7.5	6.8
19.9	6160	147.14	100	18	20.3	0	0	0	0
Code:
0.02	2720	27.8	980	1040	0.4	0.8	0.665
0.8	2800	100	1970	1320	1.2	0.775	0.805
1.6	3000	152.6	2360	2000	2	0.845	0.85
2.4	3280	182	2390	2370	2.8	0.87	0.87
3.2	3520	181.2	2370	2400	3.6	0.87	0.865
4	3800	175.9	2300	2340	4.4	0.875	0.875
4.8	4000	171.4	2210	2300	5.2	0.88	0.88
5.6	4240	160.2	2100	2110	6	0.875	0.875
6.4	4440	157.9	2030	2060	6.8	0.875	0.87
7.2	4640	154.1	1950	1970	7.69	0.875	0.87
8.09	4840	151.1	1890	1940	8.61	0.88	0.87
9.01	5000	148.9	1840	1890	9.41	0.885	0.875
9.81	5160	145.9	1790	1860	10.21	0.89	0.885
10.7	5280	141.4	1780	1830	11.2	0.895	0.88
11.6	5440	137.6	1760	1810	12.09	0.89	0.875
12.49	5560	134.6	1750	1770	12.89	0.89	0.875
13.29	5680	131.6	1750	1760	13.69	0.89	0.875
14.09	5760	131.6	1740	1740	14.49	0.885	0.875
14.89	5840	128.6	1720	1710	15.29	0.89	0.885
15.69	5920	125.6	1710	1660	16.09	0.89	0.88
Code:
0.05	2480	25	0	1020	0.4	-1.7	3.1
0.8	2440	25	0	1020	1.2	-1.7	3.1
1.6	2520	24	32.2	1150	2	-1.7	3.1
2.4	2680	23	55.7	1510	2.78	-1.7	3.1
3.18	2840	21	71.8	1820	3.58	-1.7	3.1
3.98	3120	21	87.1	2230	4.4	-1.7	3.1
4.78	3400	22	91	2380	5.2	-1.7	3.1
5.7	3640	24	91.4	2360	6.21	-1.7	3.1
6.69	3960	27	91.4	2300	7.1	-1.7	3.1
7.6	4200	30	84.7	2220	8	-1.7	3.1
8.4	4400	33	80.4	2110	8.8	-1.7	3.1
9.2	4600	36	80	1960	9.69	-1.7	3.1
10.19	4840	39	80	1900	10.61	-1.7	3.1
10.99	5000	39	79.6	1880	11.39	-1.7	3.1
11.79	5160	42	79.2	1840	12.19	-1.7	3.1
12.59	5280	44	79.6	1830	12.99	-1.7	3.1
13.39	5400	45	79.2	1810	13.79	-1.7	3.1
14.19	5520	45	79.6	1780	14.59	-1.7	3.1
14.99	5600	47	79.6	1750	15.39	-1.7	3.1
15.79	5720	48	80	1740	16.19	-1.7	3.1
16.7	5840	48	76.5	1720	17.2	-1.7	3.1
17.6	5920	49	75.3	1670	18	-1.7	3.1
18.4	6000	49	74.1	1650	18.8	-1.7	3.1
jonnyblease
141
im running 97 ron bp ultimate as shell had ran out of V power :(
And im still on the little SMIC
I have been doing some research and solutions i have been looking at are lower temp spark plugs (BKRE7s) and use V power all the time instead of shitty BP ultimate and then re-log.
How does that sound?
jonnyblease
141
thanks il have to get some octane booster in for the time being as i have a tank full of BP ultimate. Il get some BKRE7s ordered tommorow. Hopefully i lhave an update of the logs over the weekend. I hope i can achieve some sub 6 CFs
Thanks again for your help guys
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
i would just take it easy till you get it sorted, cooler plus would be better and fmic wouldnt hurt. lol i wouldn recommend cf over 3
jonnyblease
141
moneys a little tight as the moment as im a student but im hoping santa could bring me a univseral FMIC
