co004
Hi All,
My car has been having boost problems whilst accerating. Basically the boost cuts in and out. I've done some block measuring in 3rd gear, could anyone shed any light on what they think the problem may be?
Many Thanks in advance...
Code:
Saturday 28 February 2009 21:41:09
06A 906 032 HN 1.8L R4/5VT 0002
Group A: 003 Group B: 020 Group C: Not Running
Idle speed Air mass in Throt Angle Ignit Angle Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME 700-820 rpm 2.0-4.5 g/s 0.2-4.0% 0-12 BTDC TIME TIME
MARKER STAMP /min g/s % °BTDC STAMP CF CF CF CF STAMP
0.44 2160 42.19 99.2 18.8 0.84 0 0 0 0
1.24 2440 64.14 100 13.5 1.64 0 0 0 0
2.05 2840 92.94 99.6 5.3 2.55 0 0 0 0
2.97 3240 95.89 96.9 18 3.35 0 0 0 3
3.77 3600 47.86 22.7 27.8 4.17 0 0 0 3
4.68 3960 61.06 25.1 19.5 5.17 0 0 0 3
5.57 4320 133.33 29.4 9.8 5.97 0 0 3 2.3
6.38 4600 155.47 94.9 13.5 6.79 0 0 3 2.3
7.19 4880 106.33 88.2 24 7.59 0 3 3 2.3
7.99 5280 166.5 100 12.8 8.39 0 3 2.3 1.5
8.81 5520 171.61 99.2 12 9.3 0 0 0 0
9.7 4880 15.81 5.9 5.3 10.1 0 0 0 0
10.5 4240 8.69 6.3 3 10.9 0 0 0 0
Code:
Saturday 28 February 2009 21:47:24
Group A: 115 Group B: 031 Group C: Not Running
Engine Speed Engine Load Spec. Boost Actual Boost Lambda Factor Lambda Factor Bin. Bits Bin. Bits
TIME 700-6800 RPM 15-150% 990-1800 mbar <=1800 mbar TIME TIME
MARKER STAMP /min % mbar mbar STAMP STAMP
0.01 2280 90.2 1700 1190 0.4 0.98 1
0.8 2600 124.8 1700 1620 1.22 0.98 0.96
1.62 2960 168.4 1690 2140 2.11 0.96 0.95
2.51 3360 142.1 1630 1700 2.93 0.9 0.95
3.33 3720 104.5 1620 1320 3.84 0.92 0.95
4.32 4120 108.3 1650 1350 4.74 0.91 0.9
5.25 4560 112.8 1650 1720 5.73 0.86 0.81
6.14 4920 151.9 1650 2290 6.54 0.85 0.89
6.96 5280 160.9 1660 1930 7.44 0.78 0.81
7.85 5640 130.8 1470 1560 8.25 0.81 0.84
Code:
Saturday 28 February 2009 21:50:59
Group A: 118 Group B: 032 Group C: Not Running
Engine Speed Air Temp In Boost Dut Cyc Actual Boost Idle O2 Adapt Run O2 Adapt
TIME 700-6800 RPM <=110 C 0-100% <=1800 mbar TIME -10-10% -10-10% TIME
MARKER STAMP /min °C % mbar STAMP % % STAMP
1.01 2800 20 51.4 1990 0.6 0.9 -6.3
1.81 3160 18 71.4 1360 1.4 0.9 -6.3
2.62 3560 20 0 1740 2.22 0.9 -6.3
3.44 3920 21 0 2350 3.02 0.9 -6.3
4.33 4280 21 36.9 2300 3.93 0.9 -6.3
5.13 4640 21 59.2 1940 4.73 0.9 -6.3
6.03 5000 24 65.9 1760 5.55 0.9 -6.3
6.94 5360 26 47.8 1360 6.44 0.9 -5.5
