Hi,
Had a spirited run home from work and had VAG-COM running in the back seat.
1st section is about 500yds of dual-carridgeway so i got a good idle to near max 3rd gear run, had to slow down due to speed limit (sorry, stop rolling ur eyes) and a roundabout.
Have put the rpm and torque data into excel, calculated for kW then converted to HP. Have links below to the plots as PDF and the data.
The peak power is showing as 215.4HP at 4066rpm and 337NM torque...
That cannot suerly be right for an 08 2.0 TDI FR 170 with 5k miles!?
http://www.sigen.plus.com/data.xls < Excel Data
http://www.sigen.plus.com/hp-output.pdf HP output plot
http://www.sigen.plus.com/torque-rpm.pdf Torque and RPM data
Its not been modified (as far as im aware) so im thinking there must be some measurement error or delay between the RPM and torque which gives a false reading....
I did add some millers in the correct concentration to the Asda fuel, that cant do it?... can it!?
Any ideas?
Stuart
Any ideas?
Stuart
