vag com fault help
teeth2k
908
sussex
i have ran vag com and found this fault
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 037 906 024 BE
Component: DIGIFANT 3.2 2121
1 fault found
00522 engine coolant temp sensor (g62)
27-10 implausible signal intermitant
readiness n\a
i have changed the coolant temp sensor and ran vagcom again only to find the same results .
any help please?
Santos_V
You might want to check the wiring for the sensor or replace the sensor again. I have heard a few times where the code was set do to faulty replacements.
