vag com fault help
teeth2k
908
sussex
i have ran vag com and found this fault
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 037 906 024 BE
Component: DIGIFANT 3.2 2121
1 fault found
00522 engine coolant temp sensor (g62)
27-10 implausible signal intermitant
readiness n\a
i have changed the coolant temp sensor and ran vagcom again only to find the same results .
any help please?
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
On the main screen go to "Select" you will see a load of tabs you will need "01 Engine"
This will scan address 01, once it's scaned there are tabs at the bottom. Go to "Fault Codes" and in there you can clear the fault!
Have a look on Ross-Tech.com
teeth2k
908
sussex
sorry dave have only just got around to looking at this but thank you very much......:rolleyes:
anyhow i have cleared the fault and took the car out for a spin and guess what ?
problem still there ... did another scan and same fault so im stuck now. Does anyone have any ideas??? please
