Vag com engine faults cleared themselves?
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
I have recently just got an Arosa 1.4 PD TDI and it has just failed to start a few days ago! The starter motor cranks but she doesn't fire up!
I plugged in vag com today and earlier got 2 engine faults come up, think one was the N249 valve? Anyway didnt log them and went to check again earlier and the faults have now cleared by themselves! Checked 4 times and now coming up with "no fault found" I haven't cleared the faults and she still doesn't start can anyone help please?
cheers
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
Nothing special to say here, each fault code has a specific reset counter, that clears it after a certain amount of ignition and/or warm-up cycles. It's also possible the ECU simply lost them but that would be rare.
But the fault still exists so shouldn't a new code flash up after I tried to start motor again!?
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
Just did a check on the car and here are the results:
VAG-COM Version: Release 409.1-US
Chassis Type: 6H - Seat Arosa
Scan: 01,02,03,08,15,17,25,35
Address 01: Engine
Controller: 045 906 019 T
Component: l,4l R3 EDC 0000SG 1209
Coding: 00002
Shop #: WSC 06441
VSSZZZ6HZ4R002356 VWZ1Z0C2537355
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Controller: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 05603
Shop #: WSC 00000
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
She just started up after days of non running! She drives real sluggish tho compared to norml but this passed after bout 20 mins of running. A falut code has now come up too!
Address 01: Engine
Coding: 00002
Shop #: WSC 06441
3 Faults Found:
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
P3105 - 35-00 - -
18027 - Shareware Version. To Decode all DTCs
P1619 - 35-00 - Please Register/Activate
17957 - Shareware Version. To Decode all DTCs
P1549 - 35-00 - Please Register/Activate
Readiness: N/A
Coding: 05603
Shop #: WSC 00000
Anyone shed anylight please? Is this the valve at the back of the engine next to the water bottle? As this valve is clicking like mad when running and with ignition on!?
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
Had seat look at the motor and they have cleared the codes down and took it for a test drive, they said it was driving fine and the codes didn't come back! Its been 2 days now and the codes still haven't come back so I dunno what happened!?
