Vag com`d a LCR Possible coilpack?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
*** just had my mate round to scan his LCR with vagcom, Im a total n00b to vagcom literlly got it yesterday so a little unsure what im looking for?
It came up with these faults once scanned
17968 Maximum engine speed exceeded, Now *** read up on this and understand theres nothing to worry about as he`s just had it remapped and proberly revved the tits off of it. Correct me if im wrong
17763 - p1355 - 35 - 10,- intermittent Is this a coilpack gone in cylinder 1? or would the coilpack poped off?
17766 - p1358 - 35 - intermittent 10 Same as above but cylinder 2?
Cheers David.
Sorry mods i posted in the vag com section aswell need a fairly rapid response so posted here too
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Maybe so... but as its a 1.8T i assume they would flag the same fault codes as the ibiza and as i own a Ibiza cupra i thought id post it in here as this is my regular section. And i know some of the lads in here are pretty clue`d up on vag com in here....
Acid where are you!
David.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Nah not old codes mate as he had it remapped 2 weeks ago by p torque and had no faults then plus he said its missing really bad!
David.
May 25, 2004
2,691
Newport, South Wales
Constant missfire? Or at a certain point in the rev range?
If the later then try plugs if constant 99% coilpack failure. As Tom said, try swapping coil 4 for 1 see if a code appears for that cylinder
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Sorted now on his way down to me yesterday he had the EML come on, So we cleared the faults and took it for a run was missfireing at 3k rpm we we got back scanned it again and it came up that cylinder 1 had a misfire! he`s since changed the coilpack and all is well.
Cheers guys!
