Vag Com codes, help
G_Man
101
Darlington
3 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
Today:
16518- Lambda sensor, no activity
Mass air flow problem has been sorted so neednt worry about that anymore, its just the other 3 im worried about, i didnt copy and paste the codes and words today, so the last one is just something along the lines of wht it said. Just wondering is its as easy as changing the lambda sensor or could it be something puttin the lambda sensor off and making it give this reading?? Also which lambda is it? The charge pressure control one, been told something about N75??
Thanks in advance :)
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
did you reset the faults and take it for a drive (maybe even a few days) after then check for faults again?they could all be related to the maf going faulty. The faults could all have risen from one problem or collected over a period of time, clearing them will show you which ones come back time and time again.
G_Man
101
Darlington
yeah i cleared them on wednesday i think, the top codes were what i got then, and i cleared them and tested again today.
and got these
