Vag com and radio change.
Rob_Talisman
MKII CR FR 170 FL Stage 2
Sep 2, 2013
811
North East
Hi since i swapped out my rns310 to an rns315 i get can bus. Navigation and telephone error in vcds.
Is there anyway to correct this. ?? Thanks
SamTurner
26
Sheffield.
Are the connections on the quad lock the same on the back? like the pins for nav etc in the same place.
Also i didn't even know Odis was available yet lol
SamTurner
26
Sheffield.
ODIS, sorry keyboard!
Yeah thats what the new software looks like we use on VAG cars now. It might just be the lay out of the programme you are using. At another glance that seems to be the case.
Have you tried coding in the telephone part? Maybe plug in your old radio, get the code from that and then reenter it into the new radio?
MJ
5,547
33
Manchester
He's using VCDS/vag com not ODIS.
It is now available from the likes of eBay but is still **** slow and a pain to use.
VAS-PC and VCDS make a far better combo.
As for the faults is see if you can remove the functions in long coding helper. If it's flagging a fault with a component you know you don't have installed then remove it from the coding and the fault should erase.
SWANSWAY CUPRA Dealership
