Mr Bigglesworth
385
Herts
Siyuation is the proper VAG COM stuff is too pricey for me so its going to be a cable off fleabay.
I can either get a USB cable to use on my fairly up to date Dell laptop with VISTA or buy a serial cable to use with my P133 ancient laptop which runs XP.
I see many people having issues with USB stuff and also VISTA can cause issues. Haven't seen so many comments on serial fleabay cables - is this because they are better or because no one buys them any more?
Which is likely to cause less hassles?
Cheers!
i would say serial less, not that i have one , i have the usb, which causes some stick with vista
I went with the USB - VISTA option - actually not had too many problems, key steps were
1. Under device manager changing the setting of the com port to be 2 (or one that was free in the range 1-4)
2. changing the baud rate to 4800
3. changing it to run in xp compatability mode.
