DanH
Hi all,
Have a problem at the moment, the central locking has packed up. I have worked out that the central locking is a vacuum system and I can actually hear a leak behind the door card when I lock and unlock.
Can anyone shed any light on how to remove the drivers side door card? Cant see any obvious way apart from just ripping it off!! I have worked out that the pump for the system is in the boot and that it works on a pressure system going around the car depending on which way you turn the key.
Anyone help?
Anyone help?
