V5 clocks???
EMSCUPRA
I am a bit confused here, i have seen other toledos with a little red L.E.D display on the clocks, its about 10mm wide and about 80mm long, this is situated below the square box that has the warning lights on it. Would this be for the SAT NAV at all or temperature display maybe?
secondly is there supposed to be a fuel light on these? or is it just the beep noise and the MAF display shows miles before you need to fill up?
any help wud be great.
midcuk
never confused!
Jun 20, 2001
335
newcastle
should be a light and beep for the fuel, normally get about 40 miles after beep depending on how you drive :)
not sure what you mean about the led bit though
GrayT
I'm Old
Jul 7, 2004
812
London
It displays the radio station, although I don't think it functions on all models.
EMSCUPRA
i have checked all the fuses to see if i can find one that is stopping the fuel light working but there isnt any fuses blown.
Any ideas people?
skinnylew
84
South east london
You should have a little orange light when it beeps and if you run it down to the red line then an orange fuel pump sign should appear in the central display.
As for the display bar it will only work with the original stereo not on aftermarket units.
EMSCUPRA
o great, my clocks must be foobard! no orange light at all and also the sterio is original, its the original sat nav supplied with the car
GrayT
I'm Old
Jul 7, 2004
812
London
I have a feeling it does not work with the later Tolly's that had Sat Nav units, but someone else who has one may correct me.
