V5 Air Conditioning cut out
jam
Ive a temp control problem with my V5 air con. When the outside temp drops below 2 c then the air con cuts out and the interior mists up immediately. With very cold weather on way it would be a mare driving round with with windows down!
I suspect the system hasnever had a service,do think this would cure the problem?
Jim
Feb 26, 2009
5,275
Wolverhampton
I believe that is correct operation. The air con isn't designed to run at very cold temperatures, after all it is designed to cool a hot car rather than warm one up. It's like having a fridge in an igloo.
Just use the warm air blowers with the air con off to get rid of misting.
kewe
814
Edinburgh
Yep its a safety feature as below 0-2 degrees the condensation in the system could freeze causing it to fail. Think this is the norm for most aircon systems?
GrayT
I'm Old
Jul 7, 2004
812
London
It's normal. I find that if it does mist up a 1 min blast with the screen directed fan is normally sufficient to clear it.
