Urgent - N75 how should it be plumbed in?
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Hi Guys
Just about to go down to PTorque but wanted to check my N75 valve is connected up the right way before I drive down and he says its not
My problem is only getting 10psi after a remap
Has anyone got any pictures? I will upload one of mine if not
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
heres how mine is
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Well just about to set off on the 2 and half hour journey so hopefully will find out today
If it was in limp mode thou it presume a fault code would come up
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
WOOOP WOOOP Finally got 15.5psi stupid N75 wasn't setup right
Cheers to Will at PTorque for sorting it out
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Well Will did mine so it maybe worth speaking to him as he said it set too high it can cause some damage
He has a section on here
R4cup
Beef NO Burger
Jul 28, 2006
1,757
In the garage
oh, its just that mine is oldskool chipped, was running 17psi with 5psi spikes, changed the N75 and now it runs 10psi, going to 14 over 4.5k.... :(
how did you adjust it?
There's a little hole at the side of the N75 with a screw inside which u can turn but i wouldnt mees as i did & car would run no more than vac pressure :censored:
Aug 29, 2010
587
suffolk
Dougy nice car mate, just thought i'd let you know the R still running very good and still alot of fun going to be playing with it soon.
do you still miss it?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
n75 is not adjustable
check you have piped it back correctly and no loose pipes after fitting yout tip
