Uprating My ARB
steveoelliott
55
Hi,
I've got a 2003 Ibiza TDI 130PD Sport.
I am going to buy all the bits to uprate my ARB to the Cupra one. Do I just need the ARB and bushes or will I need new droplinks too.
Also is there anything else I should get replaced / inspected by the garage when they are fitting this. I take it they might have easy access to other bushes that might as well be replaced / uprated at the same time.
Many Thanks...
Sisson
Club member
Aug 18, 2005
1,662
Derbyshire
Go for the fabia front arb as its cheaper and the same thickness
If you change the bushes go for cupra 160 front wishbone rear bushes and the powerflex front wishbone front bush
You could also get a strutbrace to tighten the front up and a Fabia vrs jabba rear arb aswell if you want...
steveoelliott
55
Any ideas whether I will actually need new droplinks to fit this. Also is it really true that the Fabia one is bigger.
