Uprating lights....
slimjim
Professional Muppet
Feb 1, 2005
1,172
Telford, UK
www.jameshardacre.com
OK ... so the HID's are in ... and they look SO good...
(will post some piccys of installation later today)
BUT ... now the rest of my lights look PANTS....
So, how do I make them all look kool?
I suppose I could just chuck LED's in everything for £30ish? But I want to avoid the problems that Vicky (Well Stu) has had with her Beeza....
http://www.seatcupra.net/forums/showthread.php?t=73502
http://www.seatcupra.net/forums/showthread.php?p=799026
But what can I put in my sides to make them look white rather than yellow... to try and match the super sweet HIDs?
:blink:
stuart_hatch
Poor Student
Aug 28, 2005
318
Glasgow
I have philips blue vision side light bulbs that do look a bit better, but still yellow.
Best soloution i have seen is the piaa led bulbs, expensive yet dam bright.
Only thing is that the sidelight bulb location is right next to the full beams and that leds dont like heat and over time may flicker
slimjim
Professional Muppet
Feb 1, 2005
1,172
Telford, UK
Those piaa's look good.
£25 ish for a pair? Dosent sound too bad. What size are the Leon sidelights?
H**?
Plus I was thinking of getting the led rear lights.... the ones that are also direct replacments... along with LED indicators.
But im worried about changing ALL of them after the problems VickyM (Stu) had....
but as it's a diesel... the battery should be better... shouldnt it? Or is it not a battery problem? Vicky M(Stu)?
slimjim
Professional Muppet
Feb 1, 2005
1,172
Telford, UK
stuart_hatch said:
Leon's have 501 size sidelight bulbs, the problem that VickyM is to do with the differnce resistance given by all the LED bulbs
Right
So I want
piaa sidelights (501),
LED indicators front side and rear (Standard sizes)
and dule LED brake lights (?)....
Anyone want to guess if I would have problems with putting these on the diesel Leon?
And will I be able to get the lot for under £50 or would it be more like under £70?
stuart_hatch
Poor Student
Aug 28, 2005
318
Glasgow
slimjim said:
Right
So I want
Im not 100% sure about going toe the indicators as they will have a lesser resisitance and you will probably end up with them flashing quite fast.
stuart_hatch
Poor Student
Aug 28, 2005
318
Glasgow
chiefsilverback said:
How do people get round the legal aspect of HIDs? Surely when it goes in for an MOT you'll fail?
Tecnically yes, but everyone i know with them got away with them no bother
chiefsilverback
Terrible thing a poo poo!
Mar 21, 2005
234
RTW, Kent
Given the government penchant for extracting as much money as possible from the humble motorist I can't believe it will be that long before they cotton onto after market 'illegal' HIDs and start raking in the cash!
Spanky
Banana Virgin..
Feb 5, 2005
584
Preston, Lancashire
I had these, after 3 months they started blinking due to the full beams heating them up too much.
Its probably luck of the draw, my first set did that after a couple of months, but my current set have been on for over 18 months now, and not a problem. Even if they only last 12 months, whats £8 a year ??
adam_tdi
dervmeister
Feb 27, 2005
174
walsall
www.peugeot-gti.net
im about to order some new bulbs to go with my hid,s
here is a pic of the 6 led bulbs from ultraled if u wanna know what they look like
Mar 18, 2003
1,249
In oncoming traffic
Ultraled's now do a flasher unit from BMW which has led indicators if you use this and 4 minimum led indicator bulbs you will not have the problem off the flasher unit seeing too low resistance and flashing a double speed as if you had blown bulb!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
use the 501 sidelight listed for the ibiza cupra R from a seat dealer
N 017 753 10
looks a watery blue but lights up a pure white - makes a std bulb look arange
and about £2.50 ea iirc
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Ive got the flickering LED problem. Glad i had look on here as i thought it was a duff bulb! So is there anyway around it or is it suck em and see? as my last cheap set lasted just over a year? Bugger just read there bit in red and it says they will flicker! Are HIDS hotter or colder than stock lights or no difference?
slimjim
Professional Muppet
Feb 1, 2005
1,172
Telford, UK
HID's are LOADS hotter... certain makes are NOT for use with plastic lenses (most jap imports have plastic lenses)
If you drive with them on for ten mins or so and park up, if it's been raining, you can see steam cominoff your lights if it's a cold night.
Nothing to worry about on your cars.
But because they get so hot, if they get any type of dust or grease on them, they burn through when they are on and explode, which is why you NEVER EVER touch them with fingers.... or ANYTHING for that matter... :D
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Same as halogens then!
Im just looking into new side light bulbs and i dont wnat to pay another £8 and have my HIDS kill them! (not got HIDS yet by the way just stock leon lights)
slimjim
Professional Muppet
Feb 1, 2005
1,172
Telford, UK
What sides are you putting in?
I have LEDs in mine (No, they are not a silly colour) they are white to look right with the HID conversion.... and they run fine. Not had any issues with running either standard or the led sides with my HID's.... :)
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Ive got 4 bulb LED types (white as well matey). Only noticed it flickering the other nite when i was behind a van. Just wondering if there was a 501 bullet style bulb that was better. If not im going to chance the LEDS again
