Yesterday I spent the main part of the day with Andy Jackson at ITG, and this was predominantly based on the back of the thread I posted about the clamp tightness issues I'd been suffering (where the hose clamps were loosening over time after heating and cooling, particularly the one connected to the turbo unit).
Aims from the day
There were some overarching objectives for the day, and these were:
A fairly comprehensive list, but Andy made it absolutely clear that whilst they are incredibly busy on other projects, he/ITG are an organisation that encourage customers to share constructive feedback. Likewise, if further ITG investigations find this feedback to show any merit, it could well be investigated for integration into future product development or revisions.
SETTING THE SCENE - Please ensure you read this ahead of the findings to ensure no confusion
I want to make some key points absolutely clear here, so I am going to highlight these points in the hope they are interpreted and understood with the right intent, and hopefully this will stop this thread turning into a contentious fracas.
Now we've got the small-print resolved, and hopefully everyone understands the sentiment behind the development I will begin with what we achieved yesterday.
DEVELOPMENT DISCUSSIONS
1) MAF PIPE DIAMETER - REAR STEP DOWN HOSE
It's always been a key selling point (for me anyway) that the 66.5mm MAF pipe diameter on the ITG system replicates the one supplied in our OEM engine covers. I've always believed that this was a key factor in delivering consistent, measured performance, and side steps some of the issues I've read about on other aftermarket manufacturers systems where larger diameter pipes have been used.
So whats the issue here? The fact is I didn't have one personally, but a slight intermittent flat spot I was getting at 5,100rpm raised suggestions from my independent VAG tuner that they were concerned by the 45 degree pipe diameter step down in front of the MAF sensor. Their concern was that the step down was causing a barrel wave of air over the MAF sensor at certain airflow conditions which meant that the airflow over the MAF sensor was disrupted enough to cause a variation in performance. Their suggestion was to look at fabricating a fixed diameter 67mm rear pipe to allow the air to settle way ahead of the MAF sensor.
Andy showed me a range of air filter housings/MAF pipes for R8's, A3's, Jags and others, and there doesn't seem to be any consistent rules as to how the airflow is managed over the MAF sensor. In some cars there are step downs or lips quite close to the sensor so this would suggest that as long as there is a slight but defined gap (and not a very long one) ahead of the MAF for the airflow to settle this should not be causing any significant performance related issue. He will continue to investigate this in more detail, but I was satisfied after he showed me a range of prototype pipes that had been used in development of the K04 kit (and showed no real benefits in performance) that this is probably not the key issue.
2) HOSE CLIPS - PARTICULARLY THE ONE ON THE TURBO HOUSING
Andy / ITG have been making CAI systems for cars for a long time now, and as a result are one of the pioneers and key innovators in the field of induction technology. As a result many of their solutions are tried and tested. Whilst that is the case, the world of VAG is a newer area of their portfolio of offerings, and some of the kits they offer for us are in their first evolution of long term testing.
The clips supplied in the K04 kits are the same as the clips supplied in all of their systems, and to date they have never suffered any issues with slackening or loosening as I have been suffering on my kit.
Andy has been investigating cost effective alternative hose clip options that may work better for high boost / high temperature environments , and has sourced the following clips which are not only THICKER, but also have an internal spring clip tensioner which helps to maintain tension on the pipe during heat expansion.
After sourcing some of my own intercooler hoses (which incidentally did not fit), which used a more robust clamping mechanism to compress the clip, there is always a risk by using these 'sledgehammer to crack a nut' solutions that you can cause other issues. The ITG system is a lightweight solution with aluminium piping, and there is a real issue around over-tightening heavy duty clips and damaging the piping from over compression.
I will continue to monitor these new clamps over the next few weeks, and if they are successful alternatives they will be available to order through Andy as an upgrade. Again, I am not sure all owners are having issues, so check your clamps and if they appear to be tight and you are experiencing no unusual effects with your car, this upgrade is not a pre-requisite).
INITIAL FINDINGS
I seem to have less 'turbo whoop' at low revs, and the system seems quieter. When I say turbo whoop, its a name I give to the sound which the turbo makes on spool up from stand-still which is prevalent and occasionally annoying when driving in stop start traffic, or around town. I will check the tension on the pipe later today and report back with periodic ongoing post updates as to how its holding up.
Aims from the day
- To investigate potential solutions for the hose clamp issue
- To review my findings on the effects of removing the heat shield near the filter head
- To discuss the 45 degree step down of the pipe work ahead of the MAF pipe
- To investigate and install direct cold air pipework to feed the filter head
- General 'wash up' conversation to review some of the feedback and findings that have come up from the original thread I wrote, and any feedback I've received from other forum members.
- I have had some niggling issues with my car. As a result of this I have been paying independent parties to investigate these, and NOTHING on the car has been overlooked. In the original thread I started where I highlighted some findings on the ITG K04 system were meant to be EDUCATIONAL or enlightening, and an informative heads up for owners, and NOT to be interpreted as an attack or deformation on Andy / ITG / the product. I would be VERY disappointed if this thread degenerates into a mix of crossed words about ITG's proven product, OR provokes e-mails being fired towards ITG either criticizing the product, or highlighting to Andy that a thread is being written as a slander to his product. He knows about this, has been sent a link to this thread, and will undoubtedly be following it to conclusion as the ongoing testing continues.
- The ITG product is proven. Extensive tests have been undertaken to deliver a quality product which can deliver up to 40bhp performance improvement with the appropriate modifications on board. Any findings presented here are either personal (based on findings after a long European road trip in April), or in response to feedback I have received in PM's or postings from this or other VAG sites. It is imperative to remember cars ARE NOT BLUEPRINTED at factory. They will all have their own running characteristics based on how they have been serviced, treated, driven, modified, or how they have been built (in batches - maybe with parts supplied by varying supplies - eg. LUK/Sachs), so some of the findings here may OR MAY not reflect others S3 ownership experiences.
- Any changes that have been instigated from the development session and then outlined in this thread are purely part of developmental testing, and not necessarily a defined finalised solution - therefore they are not currently available as a package for immediate sale from ITG. It may be that none of the changes bare any fruit, so I would request that until we have conclusive evidence that these changes have delivered benefit there is no reason to be contacting Andy asking to supply packs. By all means register your interest based on what you read, but I strongly advise you give this thread time to develop.
- To reiterate, this has come about from a personal investigation, and I want to be CRYSTAL clear that whilst I want the car to operate within acceptable and safe operating parameters (for the ECU), my PRIMARY OBJECTIVE here is to make the car drive consistently in a linear fashion without flat spots, surging, whilst delivering great power. If I lose a few BHP/torques but improve the overall drivability of the car, I see that as an acceptable compromise. Therefore whilst I will be logging the cars performance, I will also be using personal judgment to assess how the car drives (numbers are good, but don't always reflect in a great sensation from behind the wheel as a daily driver). Be mindful that when reading these development findings, YOUR PERSONAL OBJECTIVES may be for outright power rather than smooth day to day running with an increase of power, so don't expect these changes to work universally. I will try to ensure all findings are backed up with facts, but there will be some personal interpretation here so it's not all going to be based around numbers.
- One of the reasons I kicked off investigations with an independent VAG specialist (rather than with ITG directly) is because I wanted to be absolutely sure that ahead of going back to them with any findings or recommendations, the appropriate research and testing had been conducted so I didn't waste their time. We live in fiercely challenging economic times, and I am aware this is not a huge volume seller for them to have the freedom to pour money into ongoing development. I have always been happy to 'fiddle' (and I choose that word advisedly) if I think I can improve something in response to any issues I may be facing (e.g. heat soak in pipework), but once I've paid my money for something I don't ever expect the manufacturer to have to get involved with my meddling. Yesterday Andy gave up a Saturday for me to get involved with my ramblings / findings (substitute as necessary post development testing!), and to me that spoke volumes about his personal commitment, ITG's standpoint with respect to their reputation in the industry, and the passion Andy has to perfect what he does. It's becoming rare that manufacturers offer this kind of external intervention and such an open ear, and I can't applaud this highly enough as customer feedback whilst in some cases is interesting can often be a valuable part of continuous improvement programmes if the company has the appetite and internal processes / bandwidth to absorb them. It meant a massive amount to me to be able to tap into Andy's enormous knowledge base, and to have access to someone who could break down some complex principles and regurgitate them into far more bite sized, manageable chunks. Beyond this, situations like this ignite my passion for buying British, and demonstrates how British industry is still alive, working well and delivering at the highest levels.
INITIAL FINDINGS
