This advisory applies only to the following products:
All Proxes® R1R™
All Proxes R888™
All Proxes RA1™
This advisory addresses the proper storage of these tires in colder climates. As seen in the picture below, tires stored and operated at sub-freezing temperatures, i.e., at or below 32°F (0°C), will lose rubber compound flexibility and may experience cracking when operated under such conditions.
WARNING!
The rubber compounds used in these tires have unique properties that, when compared to other tires, can cause them to lose some of their flexibility when stored and operated at sub-freezing temperatures. This loss in flexibility can lead to potential cracking and other damage to the tire.
TO MINIMIZE THE CHANCES OF THIS HAPPENING, CONSUMERS AND INSTALLERS ARE ADVISED TO FOLLOW THESE INSTRUCTIONS DURING SUB-FREEZING CONDITIONS:
1. Do not operate the car with these tires, as the tires may suddenly fail.
2. Always
store these tires indoors at temperatures above 32°F (0°C).
3. Before mounting or dismounting,
store these tires for at least 24 hours in a temperature controlled environment of 68°F (20°C) or warmer.
4. Remove these tires from the vehicle and deflate to half the normal air pressure during prolonged periods of non use or storage.
5. Do not move a car that is in storage with these tires, as the tires may crack.
