luke_h
132
getting a pair of fronts on at the week end as a furbing mine and they only have a bout 2 mm left so may as well do them now just wanted to know do lcr's wear the inside edge?
its not bad just the tyre has a bout 1.5 / 2mm left and the inside edge is bald just wanted to know if this is a normal with being front wheel drive or should i get the camber checked?
Mine was exactly the same, a little worrying as the outside and middle part of the tyre had loads of tread left
mine was the same inside edge was really worn, got them changed last week an got it tracked too was only 2mm out. He checked all the rubber things :) an said they were fine very little movement
