The brake wear indicator has came on and I want to turn it off.
I have fitted ferrodo pads and I have also fitted the mod to the connector of the sensor by using the red femal spade terminal to short out the pins. The indicator light stayed off for about a month since the pads have been fitted but all of a sudden light is coming on.
I thought it may have been the brake fluid level checked it and the reservoir is full, i even thought it might have been too full so removed some, but the light and beep come on.
I think I read that the light can be turned off using VAG COM, how do you do this, I have a full version of VAG COM so hope to be able to do it.
Any help would be great.
Thanks.
Thanks.
