Turbo timers
nally270lb.TQE
439
gloucester
I looked into this but there were a few people who had said in other threads that the way the Leon is wired if you fit a turbo timer you get out lock your car but the car will unlock itself. Last thing you want to happen after walking off . Maybe able to bypass that somehow . Someone will be along to say pto's and con's I imagine
Sep 4, 2012
719
Rainham essex
Oh right that's not good. Was just wondering really cause my mate has one in his focus rs and It just got me thinking and I haven't heard anyone on here mention them. Cheers anyway mate
BMH 25
57
Midlands
You don't need one dude the seats are more intelligent then the ford rubbish, when you turn the ignition off a small pump keeps the fluid circulating the turbo for a few minutes.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
That's only on the 225 not sure about the 210 the 180 doesn't have a water pump, for that purpose.
Just drive off boost for the last few miles.
Wolvo-Oleg
304
Wolves
Ha awesome! Would love to know how much time I've wasted letting mine cool down :lol:
Literally, just turn it off and walk away asif it were N/A? People need to know about this haha
285cupra-matty
488
Harlow
I have been told but quite a few people several of whom are mechanics, say that the water pump don't do s#@t for the turbo, when U put your foot down and hit boost you spool the turbo yes? So this motion in the turbo takes a while to slow down and the turbo's on Leon are water cooled yes? And oil lubricate's the compressor wheel bearings so if you turn the car straight off yes the water will be pump round ( if the pump still works) but the oil pressure will stop as soon as the engine stops turning thus starving the bearings of oil causing wear eventually allowing oil past making it like a ford SMOKEY.
Someone will correct if im wrong.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
yep the oil will stay static but gentle driving for the last mile is enough to keep things happy.
mty12345
3,907
538
bristol
You're quite right mate. If the turbo is still spinning then the bearings will be killed by lack of oil pressure and even if the turbo has stopped, then the oil still needs to be circulated for a minute or so to stop the oil baking and carbonising.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
____^__________________________^^
Yes. What has this to do with the price of fish?
Only on the LCR. To deal with the high temperatures they reach in full-bore running. Not because they need it when pootling along at 3000 rpm.
The turbo bearing (there's only one) is lubricated and cooled by oil flowing at a very high rate, because it's a plain bearing rotating at enormous speed and because being in the exhaust it gets very hot.
Even if you were to pull in off a racetrack after a sustained session of full-bore antics and switch the engine off straight away, the turbo stops spinning straight away too. it doesn't take minutes to slow down, and once the engine is off it's under no load. It's driven by the exhaust gas after all. The turbo components, exhaust manifold and engine will be very hot. The continued flow of coolant will bring the temperature down sooner. You'll still have cooked some oil in the bearing, though.
In real life, there is usually some slower driving before you switch the engine off, which allows the turbo to cool off. The worst situation I can think of would be pulling into a motorway services after a mad session of illegality. In circumstances like those, don't switch your engine off straight away.
ObWhinge: spelling, txt-spk etc.
