I always thought that the chatter on throttle lift was a good thing, as it meant that there was still pressure in the turbo ready for when you put the foot down again, whereas a dumpvalve dumps all the excess turbo pressure causing massive lag.
Nope unfortunately. When you hear the chatter, that is your compressor blades chopping up the air as it has nowhere to go, which drastically reduces the rpm at which it is spinning, which means it'll take longer when you get back on throttle to get it back up to speed (for want of a better term)
So This excess pressure actually can blow through the seals that contain the bearing & oil ? (& on the other side of the bearings is the Exhaust pressure ?)
I don't quite get what you mean?
If you consider that the "reversed" air pressure or "Built up" air pressur is acting backwardly on the compressor wheel, this is what damages the bearing over time, it won't force though the bearing and oil until it's pretty much gubbed? The reason for this is the thrust is generally assumed to come from the Turbine side (ie the hot exhaust gas forcing the turbine wheel round which translates into a force on the turbine shaft)
