I am aware of the length of the inlet manifold. The 20vt manifold is not much shorter, i believe , if you look and compare. However if i fabricate short intake i reckon I will have significantly reduced the lenght of the air (about 1m!?!?!) . i will consider this in the winter as this summer will be for testing reliablility and so on. As i have said before, it is a daily driver and i will stick to that decision .. a lot of people ask me - what boost level are you planning ??? as much as the chassis can take so long the car is drivable .
Back to the manifold- my concern with the lenght of the inlet piping is lag as the pathways have come quite long.
Progress - I had the car completed yesterday - fuel pump installed, IC and radiator installed, all coolant hoses , wiring done. I have to buy nuts and bolts for downpipe(
shop didn't work on Sat), Wastegate, and waiting for oil pressure flange ( to be attached between oil cooler flange and oil pressure gauge. I have installed oil return line (turbo ) and wrapped downpipe with heat insulation tape, welded (how do you call it ) flexible connection.
Basically I am left with exhaust system to do , and the oil line and can try to start the car ( hopefully tonight) .....
For exaust i am to use 2.5" pipe ( same as downpipe ) with an end can only at the beggining. Will fabricate it tonight i hope.
Here I would like to thank my frind Emo who is basically the mastermind behind the fabricating part of the project. I would not have been able to do the car without him !!!! And he keep my head cool ( when I loose it over the project) with short drives in his ABF Golf Mk3 with T3/T4 inside
Fuel rail - the Mk4 fuel rail (round type) is with changed inlet and return paths and is such a piece of craftmanship that you wouldn't believe!!!
Anyway - fingers crossed
