Turbo Project
wicca
111
All the turbo flanges are made and so is exaust manifold:)
basically I have all the kit and even managed to change the IC to a 6 liter one :):):)
I was thinking how my initiall project has been through 2 evolution stages already. :) (one turbo , then another, now a third and 2 IC) . But it is for the better.
My first turbo choice was fancy expensive one, the second one got stolen, the third one is the reasonable choice.
I still can't get off work and do the rebuild...
i will finnaly get someone to photograph the whole lot - can't afford a camera at the moment:rolleyes:
wicca
111
D DAY is tommorow ....
everything is in the boot ... expect a write up .. pictures .... swears and hopefully joy at the end
wicca
111
cheers
hope to rebuild engine and install manifold and turbo and IC by MOnday - I have the rest of the week off!!!:whistle:
what is better to spend your leave on ???? do you know ? the result of my leave would be a whoosh phrrrrrrrrr machine that leaves some powerful cars for dead.
Anything better?
:D
wicca
111
As promised I spend last week on the project...
Basically I took the head off - and put it aside as it had been rebuilt 2 000 miles ago. Unbolted manifold and chucked it out.... next was oilpan , oilpump and timing belt, pulleys etc. First thing was to check rod bearings and as expected the ones on cyl 1 & 2 (nearest to the cam wheel) showed some sign of wear > nothing to worry about but worn. Could have been my aggressive cornering with low oil level or just mileage ( my car has been through 180 000 miles) it was the same case with crank bearings where my friends at the garage i am doing all this suggested they are ok , but i insisted to be changed. I opted for Mahle G60 spec bering as they are from stronger material. I changed pitons as well (no wear on cyl walls whatsoever... a bit of the factory honing was missing, that is all) . original pistons were 80'98 mm , the forged ones i ordered are 81'00mm , the "key" on the rings is 0.03mm. I has become a very tightish but perfect fit and would require some gentle running in.
Head was put back on - used a G60 spec twin layer headgasket - fits straightaway and I hope it holds up to 1 bar....
Unfortunately the custom manifold was not ready as before the head was taken off we had to take last measurements and had to be welded as I was rebuilding the engine. It would be ready by the end of this week.
I went to the local breakyard and bought MK4 fuel rail and oil line for the turbo - they will both need some modification to fit properly. There are 2 types of fuel rails for 1.8 engines - round pipe and square pipe ones... i bought the round type and will have to change the way it bolts to manifold ( nothing in common there) and both feed and return lines... it has been measured and will be done. I also made fittings to plug the manifold holes and made beds for the top fed injectors - easy.
The IC i am using did not fit properly ( nothing ever works as planned:D ) adn required the rad to be moved up and back towards the engine...still did not clear and will need modification of the front beam ( the one that holds the engine mount) I am going to lower it about 1/2 inch and raise eng mount the same.....
I had to leave for macedonia on Saturday (urgent issues) , and I am back at work - so will have to work at nights weekends to complete this .... There is not much left to do - pipework to and from turbo ( i friend of mine needs 3-4 hour to do it - need turbo return line for oil) ... and exhaust ... i am to drive it for at least 1 000 miles NA (i.e turbo on but no boost) as i want to run engine in and re - tighten the head . And I don't want to play with mixtures and advance on a tight engine
Then I will change to G60 management and the bigger injectors ......
I have pics on my D 600 and will post later
wicca
111
I wanted to complete everything by today but it is surprising how one small thing leads to another... without manifold i cannot do the oil return pipe of turbo, nor I can re fit oilpan 100% as I have to make a hole in it - (it is fitted and attached by 2 bolts) I can't do pipework to and from turbo for the same reasons, nor I can fit IC .. .I will come round these step by step and should start the car by the end of the week
wicca
111
Right now I am 160 miles away from the project working my butt off to go back to Bulgaria and complete IC install and turbo install
I have not had the time to even download the pics I took off my phone :(
sorry guys :(
One good news
I have a friend who did his ABF engined Golf Mk III and his is already running - i can write about it too for all of you ABF engined SEATS :)
He had different approach to it guys
:clap:
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
in Vlas any time over next week..
im coming over on sunday night with me old mam to see our apartment, but i *****'d out and am only driving as far as Luton Airport
wicca
111
How long are you going to be there for ???
if not this i will be there next saturday sunday!!!
wicca
111
Well I had some issues with welding manifold as it is made of 4mm stainless steel - that held the project for aboput two weeks
on Sunday I spent 6 hours fabricating IC piping , and on Monday external wastegate and Exaust piping with a friend of mine (actually he was fabricating and I was helping )
I used SAMCO blue hoses and the polished stainless piping looks great
it is looking very crafty but I cannot download the pics from my phone!!!
really frustrating
I have changed my mind and I am going to megasquirt 2 system as it is an open log system - and it would suit the project better
Bye for now
I hope i can upload pics soon
