Turbo not working on long journeys
BMcN
Mr. Car Carer
When on a long, constant speed journey I find my turbo will stop kicking in. I can still hear it spinning, just not boosting. If i let the car cooldown and start it will be fine. Feels almost like the dump valve sticking so I will phone Forge for a service kit.
Was wondering if there is anything else to consider? Maybe N valve? (Or whatever one the Ibiza comes with as standard).
BMcN
Mr. Car Carer
Can't get on VAGCOM till the nd of this month. Seems to happen everytime i get low on fuel and put more in.
Is the MAF the sensor just behind the air filter? I have a Dynatwist on that is probably a little overdue cleaning.
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
Yes the maf is behind the filter, you need special tork bits to remove it.
I cleaned my one up and all seems fine now. I have however just ordered all my vag-com bits.
Jonzy
Isopropyl alcohol, IPA for short is what you need really. Evaporates very quickly.
BMcN
Mr. Car Carer
Ok I have not connected up VAGCOM and here is the result:
VAG-COM Version: Release 311.2-N
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
2 Faults Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 00000
No fault code found.
Address 08 -------------------------------------------------------
Controller: 6K0 959 291
Component: AUTOCLIMA-220 X03.03
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6K0 920 901 D
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00442
Shop #: WSC 00704
IMMO-IDENTNR: SEZ7Z0Y0826914
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 56 -------------------------------------------------------
Controller: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
End -------------------------------------------------------
I am guessing that it is 17536 - Fuel Trim: Bank 1 (Mult): System too lean that is the problem, but what would cause this? Sound like the MAF? I have a dynatwist and it is a couple of thousand over due its service.
Colin
133
Warrington
My readouts were exactly the same as yours - Iam all sorted now!:D
You need to change your Pre Cat Lambda sensor - This will sort the lean problem out. Bout £80 - Speak to dave at IMG.
I had this also but it has gone away since the other problems have been sorted.
Replace the sensor as this throws the car into limp mode. I replaced mine about a month ago.
Hope this helps
cheers
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Where do you get it from-
Any Chemists - £5 -ish for 500ml.
That one usually means your battery has been disconnected recently
Colin
133
Warrington
Thats what i reckon mate - Like i said i had exactly the same code thrown up and the Lambda swap sorted it. What sort of MPG are you getting?
That explains the Voltage one then caus i kept disconnecting my batt.
It will be a mixture of both to be honest. I replaced my temp sendor before the Lamda had gone and it was going into limp mode. The sendor is defo gone though.
If youve got an ibiza then you will prob need this one 059 919 501A
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
im having the same problems! lol system too lean and fuel too low (pressure? as there was plenty of fuel in there), no induction kit just replacement panel filter and only boosting to 15psi max as apposed to 20-22ish it should make?
Colin
133
Warrington
Hi,
You are probably right but rather than it being dead it is just faulty and sending incorrect values to the ECU.
I bet even though it says its lean its running rich and your geting low 20's in the MPG.
Wouldnt drive it for too long without sorting though mate.
