turbo ko3s or k04
Hugo1.8vt
the best turbo for the 1.8 20vt ibiza?
ko3s or k04?
I wanted to about 220 at most 250cv
accept up suggestions
Feb 25, 2007
1,068
cheshire
hi mate do a search on a ko3s hybrid you might be able to get them in portugal, but for 220bhp get a ko3s far more work to do a ko4
Hugo1.8vt
in portugal is more easily find a ko4 a hybrid ko3s
but the k04 is also necessary to change the exhaust manifold and down pipe
and the hybrid ko3s not
or am I wrong?
Hugo1.8vt
the hybrid is necessary to change the exhaust manifold and downpipe?
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
exhaust manifold is an optional change but well worth doing, and the downpipe needs to be changed for sure as its waaaay too restrictive
jamiebennett81
manifold and DP are both necessary
DP on the Ibiza cupra's is a big strangle point and will be needed if running more than 220-230bhp
the same with the manifold. These are only rated up to 250bhp from what I have read and will definitely need to be changed as the hybrid runs around 280bhp
technically you can run the hybrid fine on the normal manifold, but the power band would be restricted quite a bit
