Turbo Intake Pipes
jNx
241
M25 J13
www.surreymodified.co.uk
Dunno, he says it's K03 compatible in the first bit then says
*** Note: This Turbo Air Intake Pipe will fit a 01-up 1.8T with Variable Cam Timing but with K04 or Super K04 Turbo Upgrade
Confused? I am!!
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Go for the forge, as that looks like standard one, and even the replacement ones, available through RSD and others who replace the metal section for a smoother wider metal section, aint as good as the forge one!
I replaced my RSD one, with a Forge, and its much better, as the forge item replaces the whole unit, and not just the bottom section.
Remember forge 10% discount, and i thought these were £100 from forge. With optional £50 fitting, which after doing mine, is worth the £50 quid.
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
what the TIP has to do with VVT i dont know
looks like a stock one cut up and extendend, and also doesnt look that much better than standard...i'd leave it
