turbo flange
ramzy_86
92
hi i have a lc and wanted to decat it,i have added a cupra r exhuast from back to cat,and was told that if i wanted to keep cat and do a proper decat then i had to get hold of a flange so that the new pipe can fit on it,i have tried looking but cant find one,seat told me that i have to buy a new exhuast/turbo manifold and would cost around 300,which is pointless,may aswel buy a new exhuast for that,any ideas please
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
I think what your guy means is a pipe that you can put back on, like a bolt in decat, you can decat by cuttin out the car and welding in a pipe section,
won't pass an MOT unless you have a very friendly tester!
ramzy_86
92
Thanks,your right,but i forget to mention that i want to keep the cat and be able to put it back if I need to,if i dint need to keep the cat,then yeh as u said,the pipe can just be cut and replaced and welded,but need to keep the cat incase need to put it back,so need a flange to put the new downpipe and decat
thanx
