After fixing one problem, another one pops up! Last week i had a boost issue, which i found was a split pipe where i could only boost to 0.9 bar.
A few days ago i went for an 'enthusiastic' drive and noticed my cars not holding any boost at all above around .4 bar.
On a 3rd gear pull the boost will peak at 1.4 bar and just drop off rapidly. This happens in every gear where full boost is requested.
This time im 99% sure i dont have any split pipes as last week i went over every boost/vacuum pipe throughly and found only one. Im not ruling it out though, however i dont think its a split pipe.
Whilst looking over it today, i found that the vacuum pipe on the top of the actuator, wasn't loose as if it was just sitting on there, but, i could turn the stock clip round by hand had managed to pull the pipe off with the clip still on with a slight bit of pressure. Also, i pulled on the actuator rod to see how much pressure it took to open the penny flap, and to me didnt take that much force, although i had to pull with a little effort.
I fitted a new clip to the pipe and went for a run but still didn't hold boost.
I am wondering if the diaphram in the actautor has collapsed?
I have read a few threads with similar problems and there has been suggestions of a failing maf or even turbo?
Unfortunatley i don't have vac-com so am unable to get any logs as yet.
I have also managed to source a boost leak tester which i will try but wont have it until onother few days so thought id ask you lot your opinions?
Iv taken d/v off and tried another one aswell but still the same!
Cars an amd stage 2.
Thanks.
Thanks.
