TT Jacking Points "How To"
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
I have just fitted my TT jacking points and thought i would do a small how to, the first problem is finding where they should go, none of the positions on my car had grommets in them the drivers side rear was covered with under seal.
Front one.
Rear.
The next problem is getting them in, as with all things larger than the hole they need to go in some lube is needed :think: anyhoo i greased mine, i found inserting a large socket in to the rubber helped push it through.
All greased up.
Socket inserted.
Just put on the jack and push up the rubber will go into the hole and stay there then insert the hard bit. :think: and move on to the next one.
I hope this helps :D
SalSheikh
Under the Hood
Sep 2, 2009
2,760
Midlands, UK
thanks Phillc, got mine today. i checked the prices with TPS and they come to about £16 with VAT.
will try and fit mine over the weekend.
regarding the two pieces, do you fit the rubber bung first and then the other part or both together?
